Building PC for 2k budget
Hailgod
bro dynacore has so many "ready to ship" options around 2k. those are way better value.
https://dynacoretech.com/ready-to-s...in=185.00&price_max=9949.00&sort=p.price-DESC
Psychedelic Senses
Hi anyone can see if the below specs are all right for average use pc with occasional gaming? looking around a PC for 2k plus budget:
Intel Core Intel Core i9-12900K & ASUS ROG STRIX Z690 A-Gaming D4 - $1346
CORSAIR VENGEANCE DDR5 5600MHz CL36 32 GB DDR5 - $545
Choose one
Asus Tuf Gaming RTX3060 O12G Gaming OC GDDR6 12GB - $979 /
Gigabyte RTX3060 Gaming OC 12GB Triple Fan GDDR6 - $900+ /
Gigabyte Nvidia GeForce RTX 3060 - $763
WD_BLACK 1TB SN850X NVMe Internal Gaming SSD Solid State Drive with Heatsink, Gen4 PCIe, M.2 2280, Up to 7,300 MB/s WDS100T2XHE $220
Western Digital Black 4TB $239
you don’t even need an i9 for occasional gaming, just drop it to an i5 12400
NightRaven49
even if u dont want their prebuilts, they are effectively diy so its not like u die die must go for z690 with no other option. heres what i would recommend from their pricelist:
i7 12700f + asus tuf gaming b660m-plus wifi ddr5761high quality enthusiast parts, ddr5 support
scythe fuma2 rev b83good cooler, native 12th gen support
team group tforce vulcan black 2x 16gb ddr5 5200c40249cheapest 32gb ddr5 kit, no point spending extra for marginally faster kits
wd black sn850 1tb (non heatsink, mobo already has dedicated nvme heatsink)190as u wanted, ok value beside 970 series
powercolor rx 6600 fighter439cheapest 6600, decent quality
super flower legion gx pro 650w105good value quality psu, with headroom for future gpu upgrade
corsair 4000d airflow122as u wanted
total: $1949. u dont really need the fuma2 cooler if ur not doing core heavy workloads, and i would still advise u to consider cheaper nvmes as there are quickly diminishing returns; a sn770 that is more than $30 cheaper will do the job just as well as a sn850 in all but the most demanding tasks. liddat can easily save another $100+ on top of the $500 saving from ur quoted price, all while obtaining basically the same performance and experience.
i would also recommend holding out a while longer if not urgent as replied to ts, once next gen launch current gen will drop in price.
Phen8210
Hi guys,
need help to build a budget 2k PC for gaming. Need the kind soul here for advice
thank you in advance
Sub 2k RIG quoted from dynacore pricelist
CPU + MB12700F + MSI PRO B660M-A WIFI DDR4$679Good value to performance ratio
CPU CoolerScythe Fuma2 Rev.B Kaze Flex ii Tower Heatsink$83Good value to performance ratio
Ram32GB CRUCIAL BALLISTIX GAMING 3600MHz CL16$209Opt for Ripjaws V 3200 C16 if you want to save $51
SSD1TB Samsung 980 NVMe 3500Mb/s M.2 Gen3 SSD$145Keep costs low while not entering risky territory.
CaseCorsair 4000D Airflow TG ATX Casing$122A decent airflow case
Case Fans2 x Arctic P12 120mm PWM Fan$26The 4000D case only comes with 2 fans, you need this.
GPUPowercolor AMD Radeon Hellhound RX 6700 XT 12Gb OC GDDR6$635Better GPU than the ones they quoted you
PSULeadex III SuperFlower 650W Gold Full Modular$127Top tier PSU. Top up for 850W if you plan on GPU upgrade.
Total $2026
I suggest waiting for GPU prices to drop before pulling the trigger.
Phen8210
6 cores 12 threads is enough already. But even then, 8 core 16 thread already cheap nowadays.
Nah, its not enough unless you have a very strong 6 core.
CPU demanding games like cyberpunk already can put CPU like 5600 and 12400 near 100%.
Yongkit
Any possibilities if those are at 100% cpu usage upgrading game play to 4k will help to lower down cpu usage from 100% to maybe at less than 10% while increase GPU usage close to 99% ?
Phen8210
It depends on the overall setup, game title, and game settings.
In higher-res 1440p/4k, you will be increasingly GPU-bound. If you look at this, and observe, the GPU is already capped, yet CPU usage is still sitting at 80%. It is not even sitting at high framerates.
Something to note is that the player is just driving around, with not much going on. The funny thing about this game is that the AI uses a lot of CPU resources yet still behaves stupidly.
Hailgod
this kind of faceless benchmark videos are almost always faked. better to use another one for ur claims.
i5 12400f + 3060. cpu hovers around 50%.
Phen8210
I think you should use another one for your claims.
What's the point of showing measurement in a completely dead zone? This is in contrast to the one I showed, which has more entities, such as vehicles and NPCs, that better represent actual gameplay. It's obvious that the CPU usage will be higher in the busier scenario.
In your own example video below, look at BF5 during 9:57. This is an actual gameplay scenario when a player moves about with simple stuff around but is NOT engaged in combat. It's hovering around 73%, and just one projectile launched from the left and flying pass got it to 85% CPU usage.
Anyway, all these are old news to me. 1.5 years ago I upgraded from 6 core processor because the CPU is being pushed to 100% in some titles during busy scenarios, resulting in spikes and massive FPS drops.
Also, not showing their face doesn't have anything to do with real or fake. What bizarre logic. Many of these clips with no face shown are actual gameplay footage with live measurements shown on OSD. Based on my experience, they are mostly within reasonable margin. It is made for people to see the kind of framerates that are expected under the type of scenario shown, which speaks a lot more than charts and numbers alone.
Hailgod
make it simple for you. Those "benchmark" channels do not own the gpus or cpus they claim to.
The results are faked based using estimated fps and such. The usages are all bogus.
Phen8210
At this point, it doesn't matter whether the initial video was real or fake.
The video you linked, which you claimed was legit due to the creator showing face, has double-confirmed that the current 6-core does not suffice for CPU-demanding titles under busy scenarios. Besides, you failed to notice that the CPU usage in CP2077 is hovering at a low 50% only due to the zone being completely empty. In the same video, BF V easily pushed 70-90% because there was activity.
Another video below shows the owner's possession of the hardware during the first 10 seconds.
The measurements from 10:30 show 5600X CPU usage in CP 2077. Under busy scenarios, it is hovering around 70 to 90 percent. This is @ around 98 FPS which is within a reasonable margin.
Anyway, all these aren't surprising, and I have seen them from my own encounters. Anyone that has touched a couple of modern configurations and playing games with OSD monitoring is already well aware of how much a modern 6 core can do. Besides, there are more CPU-demanding games out there.
Phen8210
So I downloaded cyberpunk again on one of my systems at home and adjusted the 5800x to 6 core 12 threads.
The findings show that the GTX 1070TI is heavily bottlenecking and only manages to generate 50+ FPS when moving in the crowd. Despite being heavily GPU-bound, the CPU usage is immense in crowded areas surging over 90% at times.
When pairing this with a better GPU, such as the RTX 3060 or above, setting higher settings will easily bring the 6-core CPU down to its knees.
We are in 2022, moving towards 2023. There is seriously no need to further debate this old topic of 6 core 8 core nonsense. The answer is obvious.
Koenig168
Unless I am reading your chart wrongly, CPU usage peaks at just over 50% and not 90% .......
summer_dell
Or how about this one?
Intel i7-12700K Core Processor
Asus Tuf Gaming Z690-Plus Wifi DDR5 Mb
Kinsgton Fury Rgb DDR5 5600Mhz 32GB(16Gbx2) Kit
Msi RX 6600 Armor 8Gb Twin Fan Gpu
WD Black SN850-1TB Gen4 7000MB/s Nvme M.2 Ssd
Asus Rog Strix 750W 80+ Gold Full Modular Psu
Deepcool Gammaxx AG620 260W TDP Tower Heatsink Cooler
Corsair 4000D Airflow TG Type-C Casing
Hardware Installation(windows 10/11 Unactivated)
$ 2435/-
with this pricing, how is it not possible to have a 3060ti instead of 6600rx?
