Catalytic Converter...
Dragon
Administrator
Not OEM, is original Fiat exhaust with the embossed logo on it. The same logo appears on the rest of the mid-pipe, extractors etc.
They fail cos the muffler was for Bravo T-jet and not for Bravo NA, telling me the rear outlet pipe was in a different place for T-jet and NA. Although the whole exhaust fitted exactly without any mods or welding required.
I didn't know there was difference to the 2 exhaust as my mechanic fitted it easily without any need to mod anything. Until the inspection centre showed me the photo database on their PC.
Yup it is like that one, for stock must be exactly the same. Otherwise will be considered as mod and have to go through testing/approval/certification process. :)
lattesurf
What to do? That's why DHL from UK loh.. scrapyard don't have same model, stockist sell $700+gst. :(
viktOzzz
in SG,,, better to drive a car in stock mode....
else... all kind of BS test fail.... insurance void claim and such...
remember the case on Avixx reject insurance.... due to mod bodykit, etc....
NY__chickenpie
u saw the youtube, he pour thinner into the fuel tank to clean the catalytic convertor, seems to run fine.
Elvis_j_s
TS, maybe you can try pump higher octane fuel such like 98.. Try not to use SPC...
I have similiar problem...
RuOnline
bad qual fuel..
i used before and never want to again.
i tried both levo and non levo
I also using spc. Also ok leh. Cannot pin point like this de. I think whatever petrol in sg is good and ok. With spc my fuel consumption is better than with esso. Just weird.
Asure7
IIRC, Sg petrol is euro-4 standard. Nothing bad about SPC.
If really bad.. its still better than many of our neighbour's :p
pew
I've been using spc for many years liao.. ok ley..
Tried other brands, also same.. pickup forever slow.. :(
In fact my friend's tuner did dunno what test, found out that caltex and spc give the best burn rate
ASM_HWZ
Thanks for everyone replying my post...
For petrol used, both workshops asked on petrol I used and told me the same thing... SPC petrol does caused some issue.
When the workshop recommended me to change cat, I ask the boss whether they are confident in solving my problem; he replied YES. But the workshop got the wrong cat for me..., and clear the code and return my car. (how true, I really don't know)
I send email to KIA, and they replied within 24hrs; and wanted me to sent the car to them for inspection. Any service center I choose, they arranged the ppl there to check my car and cat. When ask why the sense of urgent, they told me it's the first case:s22:.
So I left the car with them. Next day morning, they called me to pickup the car. Issue solved.
Reason they gave: they are are using the latest ver. software to diagnose and nothing wrong, it can over-write the existing code. And they had inspected the cat and put on test, nothing wrong. Tested after over-write code, nothing wrong.
Damaged: SGD58.00++
Wataru
Damaged: SGD58.00++
Wow, that saved u a fat shietload of money!!!:eek:
