Ceiling Fan Recommendation
notti_me
There are so many brands in the market, KDK, Fanco, Amasco, Crestar, Fanztec, Acorn, Haiku etc. but duno the pros and cons. Hope the experts here can give some tips and recommendations. Thanks.
milo83
My house uses KDK ceiling fan and it's the old fashion kind, quite lasting.
d3n
no pros and cons...
some go for reliabilty, some go for looks...
i go for in btw.
Aeratron AE3
blade
My personal preference for fans:
- At least 4 speeds, especially for bedrooms. Used to have 3 speed fan but I notice that the slowest speed can be too strong sometimes but off it you will feel too hot. With 4 speeds ceiling fan, the lowest speed is usually just good enough. Living room, strongest wind must be strong enough to cover a bigger area.
- With remote control, all ceiling fan should have remote nowadays
- LED light with different brightness. Brighter light for night reading, dim light when tucking the little ones to sleep.
- Cost
- Looks (very individual), I personally like glossy black and not those wooden grain type.
runhappy
Just sharing my few cents here.
Yep, best way to know is to try yourself tbh. Very hard to say which ones would suit you best. Also depends if you want a light with it as well.
That said, I recommend choosing a DC fan. (Direct current fan)
I went around many light and fan shops in Baleister and Jalan Besar to try and feel the wind. DC fans are the most effective with the wind.
56 inch is generally a good size for the HDB living room size
46 inch or smaller is good for your bedrooms, depending on whether you have shelves/ wardrobes about and also false ceilings
Tip - Beware of fan shadows if you have a fan that will flip through the lights, it'll have a shadow all the time if your fan is too big
runhappy
I brought some acorn fantasia fans, regulated price of 599 each regardless of 46 or 56 inch size. Will let you guys know if it is any good.
Meant to be a bit stylo and functional. And would suit my industrial look of my new place.
Sent from OnePlus A5010 using GAGT
joeubk
How is your fan?
IAmZlatan
Hi guys,
I'm planning to get a ceiling fan with LED light but I don't really like the design of KDK and Panasonic. I'm also concerned about the ease of changing the light.
Which would u recommend? Crestar, Fanco, Kaze, Amasco, Acorn, Elmark or others?
Thank you in advance~
TheBaldMan
I heard many people will go JB and buy KDK. Any recommendation or reviews?
2things.Ceiling mounting not same as sg.
2nd when install need good electrician to balance.
Will have wobble if not.
Main thing is price.My hse has half sg and half msia fans due to budget.
Kdk fan has a separate thread here by itself.More info there.
ralfale
Aeratron 1 for 1 promo. Haiku look but elmark price. Very worth the deal. DC motor 10 years warranty.
