- Mar 22, 2011
nope. I have E48GP,Anyone using the KDK Airy smart fan ?
Can it connect to the tuya smart life app ?
need to use KDK own app.
lol! That is why cannot do smart homenope. I have E48GP,
that was one of the considerations before I purchased that KDK Airy. Because also I had a few smart devices on smartlife app.lol! That is why cannot do smart home
Actually in room, best not to have fan with light because it will have the strobing effect. My wife’s architect friend who did our reno said no to ceiling light with fan. To her, this kind of lighting layout is not acceptable. But understand some prefer thatthat was one of the considerations before I purchased that KDK Airy. Because also I had a few smart devices on smartlife app.
But I like the super dim moonlight on KDK, just like my Xiaomi ceiling light where the lights is super dim. I don't see any other brands offering that kind.
Why don’t buy Haiku?Just got my pointone fans installed. fan speed quite strong but rather noisy. I use speed 3 is quite strong already and the noise level is just acceptable to me (for the price level)
But there is a slight gap between the ceiling and the hugger. Told the installer to close up the gap as per Alex Teo youtube on smart fans but the installer tell me its like that one, need gap to allow some air if not the driver will spoil easily. I check google reviews also have slight gaps on ceiling which to me is not nice aesthetically.
I certainly miss my Haiku fan. Very smooth and quiet even at high speeds.
i got 4 fans in my new place which is around 2kWhy don’t buy Haiku?
can lalol! That is why cannot do smart home
Pure IR blaster is cheap, I’ve been using Tuya one for a few years, $6 from Shopee. Reliable and consistent.can la
the good thing about KDK airy is the remote is using IR (not RF)
so just need to install a smart control with IR emitter ( less than $20)
lol! That is why lo? If got money then all hoot haiku. Mine is 8 fans so can totally forget about Haikui got 4 fans in my new place which is around 2k
1 haiku is also about 2k.
anyway answer is bo lui
Actually IR+RF controller isn't that expensive, can be found under $10 from TB. Also good thing about RF is you just need single unit instead of 1 unit per room for IR. Its just as reliable, if not probably even more reliable than IR except when manufacturer that included security RF, rolling code etc.Pure IR blaster is cheap, I’ve been using Tuya one for a few years, $6 from Shopee. Reliable and consistent.
How to know is it RF or IR? The stupid sensibo is very ex. Got any Xiaomi control that works?Actually IR+RF controller isn't that expensive, can be found under $10 from TB. Also good thing about RF is you just need single unit instead of 1 unit per room for IR. Its just as reliable, if not probably even more reliable than IR except when manufacturer that included security RF, rolling code etc.
What I can say is the 2 blade is very chio. My wife’s architect friend who is doing my place said don’t buy becauseI bought 4 Aeratron fans and have been using them for 1 month...so far so good. Just that it’s not a big wind fan. Its top speed is still like a 3 in other fans.
Efenz quite nice also but I won’t pay that price, around $700 to $800. Can just buy othersHow about Efenz?
Don't have much others at the same price range. Shop told me Efenz much better compared to alaska. Yet Point one has the driver issues on Google review after 1 - 2 years.Efenz quite nice also but I won’t pay that price, around $700 to $800. Can just buy others
Probably can ask other shops. If you go Yafen, they will all recommend Alaska and Prestige. Haha! I think Efenz also not like very good. Somemore at their price for Singapore fan? No la.Don't have much others at the same price range. Shop told me Efenz much better compared to alaska. Yet Point one has the driver issues on Google review after 1 - 2 years.
Ah OK. Yes Yafen has lots of alaska. I'm siding towards Efenz but yes it's very priceyProbably can ask other shops. If you go Yafen, they will all recommend Alaska and Prestige. Haha! I think Efenz also not like very good. Somemore at their price for Singapore fan? No la.
