Circles.Life platform fee
albel81
I just know of this when I saw my bill. Not a matter of just $0.30. Just doesnt feel good about this. From my past experience with other operators, the contract I signed do not increase price unless I renew the plan. I just thought they should not just increase their price even if it is 0.30 for some platform thingy that I will probably never ever use.
dexboi
thank you for helping Circles to fund their App x ChatGPT4.1 integration.
Hey, it's free* for you to use too!
*30sens/mth
orlengtao
I think ish about $40-$50. Got some talk time dat I neber use. Got some SMS dat I neber use other than 2FA SMS. Only use it for data. I think the plan's data was like 5GB or 10GB (since I set warning in my hp for 5GB data used) but it rolls over so unsued data goes into a pool. Also have Caller-ID. Dats it.
I nid to use it to access internet on my hp and sometimes tether to laptop/Chromebook. Mainly to do document work like Google Docs, Google Sheets, accessing Dropbox, OneDrive, Google Photos, Whatsapp.
Signed up wif them in like 2016-ish and since the network was stable and at dat point the app was beri good - easy to add/remove add-ons instantly thru it. Olso could see amount of data/calls minutes/SMS used versus what I had in my plan - all which can no longer be found in the current bloated app dat dun let you add/remove add-ons and have no idea what's in my plan anymore.
suggest u switch to https://zym.sg/ (singtel) $7.77 plan or their $10.10 plan(3months free). Free 5g even after 90 days( not stated publicly). Or https://eight.com.sg/ for starhub
A Better Tomorrow
Telco service are tiered and payments are structured, based on individual needs.
If the coverage and speed are not up to one's standard, can keep switching around for the best fit instead of going for the best buck bang which does not serve the need.
There is a reason why one telco is known to be the best and most expensive too and not a MNVO.
NintendoSwitch
Platform thingy? I think it is just a charge on being a customer. There's no platform that I'm aware of
orlengtao
I want to cancel my home fibre broadband lor.
Quality of life thing lor. I won't do it personally la. Just get cheapest broadband at least can pia games and surf net properly without latency or throttled speed
