Citibank SMRT Card
yiron
wonder telco bill eligible or not
Should be eligible, the promo exclusions look exactly the same as that of the regular Citi SMRT T&C, except for the additional exclusion of groceries and 7399
duhduhduh
Just got my bill dated 19 Nov.
Can I redeem the rewards to offset my bill when I only press it on 21 Nov 2021?
Will there be any additional charges? I asume it should be fine since the amount net off. anyone can confirm?
karakorum1999
From my experience, it is certainly safe if you have no more posted transactions for the next statement.
For example, my due charges for the latest statement (dated 10 July) is $600. I redeemed $60 rewards, and then paid/fast in $540 before due date. My balance in the Citi app becomes zero, so in this case, no problem.
It is less clear if in the meantime there are posted transactions that will be billed in the next statement. Would the redeemed rewards be used to offset the amount due ($600) or otherwise? Logically it shouldn’t matter but I have not dared to try so far…
saintgtril
already explicitly excludes ipm based on mcc. this would be likely why from day 1 since they changed t&c in may that it hasn't even been awarded any form of SMRT$
no mcc7399 excluded
10% (5+5%) online promo till end Dec, the additional 5% is capped at max $800 spend
https://www.citibank.com.sg/global_docs/pdf/online-spend-and-get-promotion-terms-and-conditions.pdf
Thanks for highlighting and sharing. What do you guys plan to spend on to clock between $500 to $800 for the 10% online rebate? It excludes super market + iPayMy :(
Any tips to share? Thanks!
lucky_
Anyone have any experience purchasing from IKEA online before, can confirm if it's counted as an online transaction? Planning to do some furniture shopping in Dec. Thanks!
chiokcc
May I check with you all, is the min spend of $500, is it calendar or billing month?
Thanks in advance....
