Citibank SMRT Card
mogucon
I tried looking through Citi website after login, to find a place where I can change my trigger amount for SMS notification from existing value to an even lower amount ..... but it seems that the option is nowhere to be found ....
Login to Citibank website > Services dropdown menu > My Profile.
You'll then see "Citi Alerts" on the left side menu.
chiokcc
I got this :(
Sorry, your request cannot be completed.
Please register for enhanced security capabilities via the Citi Mobile® App to proceed with this request. For assistance, please contact us at +65-62255225.
mogucon
I got this :(
Seems like you haven't installed the Citi Mobile phone app and registered/activated the digital token? It's a bit of a hassle at first but I suppose it's more secure using the app (eg. bypass sms otp).
ThreeSteps
ThreeSteps
is there an easy way to track how much of $600 is left and also the reset date?
It is important to read & understand point#4c of the T&Cs.
If your card is quite new, just download & file the mthly statements in a folder, in sequence of the statement dates. Starting from the very first mthly statement received for the card & count up to the 12th statement received for the card, this set would roughly form the first 12-month period. After that, start a new folder since it should be the start of the next 12-month period. Note: we are talking about statement months, not calendar months.
The statements show SMRT$ earned for the month, easy to do a simple add to check if you have reach SMRT$600
When in doubt, always contact the bank to check for you.
pohw0008
For me i try to make sure every month not more than $50 SMRT. Then should be less than $600 annually?
ThreeSteps
This card (5%) is good for the occasional large purchases because it does not have mthly spending cap. If you have a regular monthly spend pattern of $600-$1k, maybe there are other suitable bank cards eg. Maybank Family & Friends card, UOB Evol, DBS Live Fresh card, etc.
devion
U guys know whether buying attraction passes from Klook app is included for the 5% rebate?
devion
i google n MCC for Klook is 5734, is not inside the bank exclusion list, so think should get the rebate.
Navillera
Hi what about FeverUp.com? Bought some attraction tickets and not sure if it'll be excluded under Travel.
jentang
Klook confirm no 5%. I used it two months ago. Transaction amt was $160. So heartpain $8 gone. Should have just used DBS live fresh.
hyperfuse
Has anybody verified if use atome to pay under the installment pay in 3 eligible for cashback?
can anybody at this point of time, 2023, can verify that using the SMRT card in Atome still gets 5 percent cashback?
i know some one responded to him but that was in 2022.
