no, excluded under utilitiesDoes paying SP bill qualify for the rebate & min spends?
You should try for yourself and see if it moves, then report back?Payment to telco using telco app used to be considered online payment....
Any kind soul can confirm if this is still the case ?
TIA!
One of the main perks of this credit card is for SimplyGo. So why would it not be compliant?Is the Citibank SMRT card compliant with SimplyGo? How to check? if not, how to upgrade to SimplyGo?
SimplyGo is just a system that accepts bank cards such as credit cards or debit card from MASTERCARD or VISA.Is the Citibank SMRT card compliant with SimplyGo? How to check? if not, how to upgrade to SimplyGo?
$500 not $600Used up my Uob one card for the month.
so will activate citi smrt cos confident of hitting the $600 qualifying amount for the statement month.
grab taxi
grab rides
gojek rides
zig
simplygo
shoppee
lazada
all the above can get 5% cashback if hit the qualifying spend for the statement month ?
should be if u met $500 min monthly spend but note caroupay charges 4.5% feeAdding card as payment methods in carousel.
will buying on carousel trigger as online payment and can get the 5% cashback ?
Caroupay is a special feature akin to some kind of protection ?should be if u met $500 min monthly spend but note caroupay charges 4.5% fee
there is only caroupay if u paying using credit card on carousellCaroupay is a special feature akin to some kind of protection ?
if I heck care protection and just payment payment from linked credit card then there won’t be any 4.5% fee right ?
SimplyGo is literally simply go: no need to add any card, just tap the card and goI confirm that this Credit Card works with SimplyGo.
Just add your card to the SimplyGo App.
Yes, online. Note that offline grocery spend is also eligible for 5%Does adding this card to FairPrice app and make payment using the app for groceries ntuc and kopitiam count as online ?
or need paywave using physical card. TIA
