Computer Problem Again
CrispyPeddler
Hi,its me again.
Today while playing games..suddenly the screen freeze and i restart the comp. Now it become no signal. I have try the following:
1. Unplug gpu and connect hdmi directly from mb to monitor..no signal
2. Reseating my ram..no signal
3. Power off from main switch..Unplug all cable...no signal
There is this 1 time i unplug and plug back my vga extender..it goes in to window...i scroll around in desktop..it freeze again...and become no signal..as of now...it keep no signal...
P.s..acer guy just update my monitor firmware due to split screen...is it monitor problem?
bugis78
go to bios...change to default setting.
make sure...it is using onboard VGA on bios.. ( to check your vga card lorry not)
Try to power cycle your monitor screen. remove all cables from monitor..press and hold the power button for 10sec.. wait other 10sec and plug in again.
remember to choose the HTMI or DVI button on the monitor. :D
CrispyPeddler
yea. i did all that. but still the same. the problem start with sudden freeze screen and suddenly no signal...restart and now it just keep no signal..
Albertphoon
remove the graphic card. reset the bios by shorting the reset pin or remove the cmos battery and put it back. then connect the monitor using the vga or dvi on the motherboard.
zachsy
omg I've had the same issue and now I can't even reinstall windows! Have been experiencing this on and off for about a year now. System Restore seemed to help but the issue just occured again a couple of days ago and I didn't have a restore point so decided to do a fresh install of windows. Now I can't even install windows properly, freezes on "Getting Devices Ready" followed by a Black Screen. Not sure which component is faulty. I think it's time I upgrade to Coffeelake.
Am using z77 sabertooth and i7 3770k btw.
yusoffb01
thats a sign of motherboard issue
CrispyPeddler
yea. ive been having this issue on and off for sometime already. its like a ticking bomb and very frustrating as u dont know which part is faulty..
zachsy
If it's confirmed a motherboard issue i'd need to check the warranty status of my z77 sabertooth since it came with 5 years warranty. Wonder what the rma procedure would be like since z77 is obsolete already.
watzup_ken
In that case, they may no longer have parts to fix the motherboard. Even if they do, the cost of repair is not going to be cheap either.
CrispyPeddler
So it happen agn..game halfway...screen freeze and turn black...restart it now stuck in black screen with blinking underscore...
Anyone have any idea whats the problem...sigh
undead102
Just curious are you using the asrock b75 pro3m board as listed on your specs list on the right?
Lethal
check ur hdd/ssd health through hdsentinel/crystaldiskinfo,
run memtest and check ur rams to see if there are any error
just find a replacement board to solve ur issue if all the above have been tested?
CrispyPeddler
Oh no. We're in the same boat! I even get black screen when installing windows at "Getting Ready Devices".
i somehow manage to finish install window after i take off my gpu and use mb gpu..
so,does it mean my gpu is the problem?
