Connecting printer via wireless
WalaVita
Printer model: Canon PIXMA MG3670
Hi, how do I connect my printer to my Starhub wireless router so that I can print with other devices like laptop, Ipad etc?
Tried searching on Canon website but there's no guide for this printer regarding this method.
Experts please advise. Thanks!!
damienloh
Do you able to connect the printer to the wireless router using Access Point Mode?
WalaVita
That's the thing, I'm not sure what Access point mode means...
Please educate me..
kandinsky
The guide is here?
http://ugp01.c-ij.com/ij/webmanual/WebPortal/PTL/ptl-os.html?lang=en&type=setup&area=tw&model=mg36
commach
Cannon entry level printer are usually using WPS for wireless setup.
Try these step:
1) Press and hold the WIFI button on the printer till you see it flashing.
2) Go to the wireless router and press the WPS button.
3) wait patiently till both stop flashing/blinking and return to normal mode.
4) Wireless setup done, hopefully.
damienloh
When you startup the printer the 1st time, it will ask you how to connect the printer. If you can also change that in the printer setting (LCD).
WalaVita
The manual doesn't teach how to connect printer to router.
The Starhub wireless router doesn't have a WPS button.
That's why stuck.
kandinsky
That's why stuck.
If your router doesn't have WPS button, did you download and run the software that is supposed to help with the wireless config on your computer? The config will have to be done on your computer, supposedly.
This is for mg3540, but should be similar:
If your router does not support WPS we have provided alternative instructions to get your PIXMA MG3540 connected so please select the 'Standard Connection Method' tab below
http://www.canon-europe.com/support...inter_wireless_connection_setup/#tab-content2
WalaVita
Nope, this is the part which I don't know how to.
How do I do it on my com?
The canon website doesn't have any manuals for my model.
kandinsky
The link I gave you earlier had a link to download the software for 3670. Did you download and run it?
Click Download to start setup.
If setup does not start automatically, execute the downloaded exe file.
Follow the on-screen instructions to complete setup.
http://ugp01.c-ij.com/ij/webmanual/...ml?lang=en&type=setup&area=tw&model=mg36&os=w
Link to manual: http://support-sg.canon-asia.com/contents/SG/EN/0301936201.html
WalaVita
WalaVita
Ok, maybe I phrase my issue a bit more clearly.
I'm able to print from my laptop and ipad, by connecting to the printer wirelessly.
But, by doing this, I will lose my internet connection, especially my laptop, as I have to disable the Wifi, and connect to the printer.
So, how can I connect the printer to my wireless router, so I can print from my laptop while still connected to internet Wifi?
Sorry if there's any miscommunication.
peterchan75
@ts,
It seems like you might have IP address conflict. If I remember correctly, Canon support help guide me through the setup.
1. Set your wireless printer to static IP e.g. 192.168.1.213 as per advice given by them.
2. Then connect to your router per your normal process.
wacko
sounds like you have set it up as Direct Connection, rather than Access Point Connection. Direct Connection means your printing source (laptop/PC/etc) connects through WiFi directly with the printer, hence the printing source will have to disconnect from any existing WiFi network that is on, hence the experience of losing internet connectivity. Access Point Connection means the printer connects to the wireless router directly, and any printing source will therefore connect to the printer through the router, by being on the same wireless network that the router creates.
WalaVita
There's no conflict.
It's just that I don't know how to connect my printer directly to the wireless router.
Canon setup doesn't have the guide for my printer model.
@ts,
WalaVita
Yes! So how can I do that? I tried to find guides but couldn't find any.
1) My Starhub router doesn't have a WPS button.
2) I don't know how to do it with my laptop
3) Canon doesn't have any guides on doing that for my printer model.
