cordless driver drill
DragonFire
I'm not sure what a SDS hammer is :LOL:
Looking for something that is able to drill through concrete for replacing those ceiling lights and compatible for screwing (screwdriver) etc.
GSB18 cordless. It doesn’t do concrete well, but it will work ok for light jobs.
Goodshot
The drill bit also 3 type , wood / metal / concrete. Make sure u use the right one
SuperClubby
Makita/Milwaukee for me.
Currently using DHP486, planning to switch over to their XGT 40V lineup.
DragonFire
The 40V line is serious beef. I won't probably ever need products from that lineup for my DIY stuff haha.
Milwaukee Fuel brushless gear is great. Accessibility seems a bit limited here in SG tho.
Just like Festool.
freshvibes
Is this GSB18 cordless an impact drill? Does it mean that it can still drill through concrete but with a longer time and effort?
yuri2
I got a cheap cordless Ingco SDS rotary hammer. It comes with batteries and charger.
So far so good, I've used it to hammer drill quite a few holes in concrete already.
I have a Makita rotary hammer also, but it's corded, and I lazy to pull cord around.
DragonFire
it is a cordless drill/driver with a hammer function :) That's how I see it. I prefer using hammer to impact as impact drivers (not drills) are a whole different beast.
It can handle concrete and brick with the correct bit. It will not handle rebar reinforced concrete mainly because rebar cutter bits are only SDS.
DragonFire
Btw all u highrise kia... please dun anyhow use rebar cutters. You will compromise the loadbearing capacity of your columns and beams.
Ideasmiths
for home drill 18V GSR alone enough?
No. gSR is only drill wood , metal it doesn't have the hammering function like it's GSB model that can drill wall.
I have the various GSB 18V, can easily punch holes in old HDB walls but difficult in new BTO walls. Need to get good drill bits and a bucket of water to cool down during drilling
keenklee
makita or bosch?
IMHO.
Bosch battery less electronics, less failure point.
Can look at Bosch GDX, if not drilling large concrete holes.
The technology is in the drill bit.
P.S. Makita service centre is in some remote location. :ROFLMAO:
brushless
Just like Festool.
I bought my Milwaukee Fuel tools mostly from overseas, much cheaper and more choices than the local dealers
