royfrosty
- Jul 23, 2009
You don't have to change casing everytime they introduce new interface. You can either get a front bay bracket if your casing allows, or a rear bracket. These will need to be plugged to the internal headers on your motherboard.
Yes. Plus this.....
In all chassis is something like a long term investment. It can go on and on. Unless it rust or something.
. i wished it was like xigmatek asgard pro which had powder coated matt finish. man, i could slide a - head screwdriver lightly on it and there would nhot even be any visible scratch...dat is wad i call good quality paint.
