CPU cooler recommendation.
sad_xiaoxin
Not looking for aio as I have an phanteks escplise p300 with an strix gpu.. Total not possible to fit an 240 aio.. Not interested in 120 aio..
Would cryorig H7 quad lumi or noctua nh-u12s be a better choice?
On my 2700x with quad lumi load temp is another 72c. Would nh-u12s be better? Or any other recommendations within the same league?
poooooo
You change what cooler or fans also no difference, your case are build with restricted airflow, just open side case, play some game and you will see how much temp it drops.
pm1078
Might as well just take AIO...
Saw on Dynacore price list CM MasterLiquid Lite 120 Cooler @ $58.. very good deal, cheaper than Air cooler.
sad_xiaoxin
Honestly.. I tried.. Only drop by 2-3c.. Only when under air conditioning it dropped more.
ronnie_gogs
Managed to get stable overclock on my old 3770k with the H7 running stable for months now. No issues and temperatures coming from a custom loop with 2 radiators are quite comparable unless I went for very high overclocks...
alienaire
the prism cooler bundled with your 2700x is almost as good as 120mm single tower coolers. you should had gone with dual tower coolers like the nh-d15 or the chunky thermalright coolers.
orbvius
cryorig H7 quad lumi is cheaper and easier to get if im not wrong.
both should be quite similar. unless u dont like the fancy led or u like noctua fan colors, then get noctua.
poooooo
have you taken into account the offset reading?
https://www.reddit.com/r/Amd/commen...the_accurate_temperature_reading_for/dxraqgy/
if not 60 degree for your chip isn't anything to worried about at all..
also which cooler are you using now, typo?
sad_xiaoxin
The issue now is seems like H7 QL seems to have similar temps.. Well i had considered larger cooler but my case has a 160mm limits..
sad_xiaoxin
also which cooler are you using now said:
H7 Quad lumi. Like i just mentioned seems like the wraith prism and h7 ql had very similar temps.. Thus i'm looking for alternate cooler and recommendation.
I do understand p300 may have limited intakes but it's not that bad as it's seems.. On the p300 with 7600k with 4.7 OC @ 1.27 with h7 ql it's <80c.
alienaire
go take a look at thermalright and be quiet, they have a couple of coolers within your height limit.
edit: there's a nh-d15 model that is within your height limit too.
poooooo
https://youtu.be/zYKlMtiO9YY?t=4m13s
seem about right. wraith prism temp vs single tower cooler.
anyway why do you even needs better cooler? If you are going to take part of ocing competition, i could understand, but those temp you are getting are normal and pretty good for average usage for gaming or productivity work.
anything cooler u will needs to go 240 rad or dual tower cooler.
