CPU keeps restarting with no beep! Help!
Koenig168
I have the exact same problem, using asrock mobo too, rig as in ------>
posted a few days ago too, but i have no time to troubleshoot. For my case i have to keep turning on and off the psu switch until the com starts all the way, kind of like "revving an engine" kind of thing.
Then the com will run all the way until i shut it down and i have to repeat the process again to get it running. Sometimes, the com blacks out and power off by itself aftr awhile of running.
Looking at nigel's thread, i see that alot of people suddenly have the same problem. I wonder why?
PSU is the one component you do not want to mess around with. If it is not working properly, either RMA or replace immediately.
poooooo
Hmm tradepac is selling
SUPER FLOWER HX 600M GOLD 600W at 108 SGD.
Is this better?
not too sure on that range, needs to wait for other pro to comment.
prefers the leadex series for modular cables.
pedokuma
my asrock board used to power up by itself and turn off. cannot power on fully. in the end, it was the processor that circuited , rma it and now working well. think asrock board got issues, if you go online and search. a lot of such problems with asrocks.
pedokuma
Woah is this reliable? I always see ppl mention seasonic
Sent from a little place on earth using GAGT
superflower is a decent good oem psu makers. i think they should change their name as ppl see superflower name, sounds cheesy and tiong. haha
Steyr69
I experienced the exact same thing 3 years ago.....it took me many hours n days of troubleshooting to finally nail down the problem to be my coolermaster psu.. The thing that throws me offguard was once the system starts up n boot, system perfectly ok. I never suspect it was my psu. Anyway, i brought the psu to ban leong n rma the set. My system works perfectly after that......
Sent from Asus ME173X using GAGT
Steyr69
Quite true....just like LG.....Used to be name Lucky Goldstar.....went to Japan.....consumers think is Hello Kitty product range. Hello Kitty have a character with the exact same name....lucky goldstar....lol.
kimsix
Imo it is safe to buy any Seasonic, FSP or Superflow psu across their range offered. It depends on your budget and power requirements.
kimsix
500W should be enough, 600W in case you want change powerful GPU.
Simiishthis
Okay so i replaced my psu with a 650w superflowerl leadex silver and it still wont start up. Really seems like its the mobo thats spoiled. Should i bring my cpu to sls for diagnosis? Where should i bring it to and how much will it cost?
noobiee
lol my rig also kana
i thought is mobo spoil
but seems like some here say might be psu
hmm maybe i will test my psu first lol
almost wanted to spend $500 to upgrade mobo + cpu liao
Simiishthis
Wa sian duno whats wrong with my com now
