CPU sometimes cannot power on
NimbleDrop
Hi I have a DIY PC, recently sometimes it cannot power on the cpu. What could be the problem
shadey
Maybe PSU old, maybe got loose cable, maybe gpu, maybe maybe maybe...
You need to try to troubleshoot
jtjt00
TS, list down all parts of your rig like those on the right -->
NimbleDrop
My rig was done in Sept 2017
CPU: AMD Ryzen 5 1600
MOBO: Gigabyte AB350M Gaming 3
RAM: G. Skill 8gb DDR4
SSD: Samsung 850 Evo 250gb
HDD: Toshiba 1TB
GPU: Zotac GTX 1050 TI 4gb
PSU: Seasonic M12II Evo 620W F-Mod
Casing: Cooler Master Box Lite 5 ATX
NimbleDrop
Yup I checked yesterday. Funny is sometimes can power den shout down, the next time sometimes cannot power on machiam no power
jtjt00
Maybe your PSU if fans fail to turn at all when power button depressed.
shadow84
Did you plug the gpu cable (8 pin) into the 8 pin ATX socket for cpu, near to I/O?
kracie17
I just follow the set up I have always been using, but only recently this happened
may i confirm only recently you have been unable to power on your pc? if so, check your connections make sure they are fitted properly.. just give them a little nudge to make them in place. if this still does not work, you might want to try swapping your power switch with your reset switch to see if its the switch problem. last resort, it could be your psu problem.
NimbleDrop
I had reassemble the connections used different power sockets but no avail, probably it’s like what you said the PSU have problem
Psycovirus
All possible options already explored and done
It would be best if you've spare parts to test the system. I would first start by replacing the Power Supply.
Do you have a 2nd computer you could rip out the PSU to test? or even loan one from a friend?
