CPU spoil? Help advice needed.
garfield82
Just recently fix up my system less than a week ago, and Blue Screen just appeared.
BCCode 124, afterwhich I couldn't log into my system anymore, keep on getting bsod during windows loading.
Tried windows PE, clonezilla, acronis, they just dont work.
Changed rams, gfx card, storage drives, dont work as well.
Only thing I can show now is this, took a photo before it restarts it self again.
Processor uplorry?
Pls advice... been a very EMO week for me... the pic show so many RIPs...... lol...
wiwi
wow just wow.. you muz have angered the tech gods. missing Corsair item, watercooler tubing issue, acrylic case scratched and now dead processor all in one week. That means one thing... you gonna strike 1st prize in 4D soon.
royfrosty
You must be damn unlucky. Like literally unlucky.
How on earth this things happen all in one week? Gosh you are like jinx to build a rig.
melovelinux
Processor uplorry?
go rma ur processor
garfield82
I got buy big sweep tix, hope what u say true ba~~~ :s13:
hope everything comes to good end.
go rma ur processor
So cfm is processor? its less than a week old, can I just do it at retail shop?
eminus
124 sometimes vcore issue..are you running in auto..try setting your vcore manually try a bit higher value
melovelinux
doubt so, the retailer will allow. most prbly got to go thru intel
u install wad OS? ubuntu?
garfield82
hmmm, but if running the system at default setting can cause this problem, den something must be really wrong liao.
Win7, thing is now i need to isolate the issue, with most of the parts i tested ok. its only left with either the motherboard or the cpu
eminus
if you RMA through intel and you told them your processor was bought less than 30 days they will insist you send it back to the store.
now the store will have the prerogative if they exchange it 1 on 1 or send it through Intel.
so if they dont want to do 1 on 1 better RMA it yourself tell them it was bought 3 months ago so no more questions.
ipadxcell
Did you ensure your H100i was properly mounted on your CPU before and when you turn your PC on?
garfield82
This is getting more frustrating than I can possibly imagining.... :(
Yes, remounted my cooler again after i read about code 124 could be something to do with improper cpu cooler mounting...
Though mounting should be the least of the worries, have you seen some distro tech support test our motherboards? haha...
Ark Law
Maybe the almighty chip wants you to use the Legendary Intel Stock Cooler in order to function
garfield82
lol this is the first post today makes me lmao, was actually picturing clarkson saying that to me :s13::s13::s13:
Tested with 2 coolers so far, h100i and Extreme 2.0 mounted from the outside. still bsod shoots like uzi
eminus
it could be your mobo in auto mode giving low volts to the chip
garfield82
I'd tried 1.15 o 1.2 manual set also cannot, 3.5ghz don't think it need 1.3 to run? Its like going to the OC territory liao.
Kinda running out of ideas liao, think just take my chip down to **** shop and demand 1 to 1?
eminus
lastly check for bent pins...else you need to RMA it..and I would suggest RMAing it yourself it will take only less than a week especially if you bugged Intel CS :)
garfield82
btw, have you tried with just 1 stick of RAM yet? Another PSU?
PSU no, ram tested already. If I go aim PSU and touch wood ah, its another CORSAIR product liao~ not to mention ram also :(
Did you push your chip too hard? (overclocking and increasing voltage?)
No OC, I run my system at default this time right after setting it up, the only possible thing I'd changed was boot device.
