CPU Temp hits 90 c
minuteez
Senpais, doesnt the chips have auto throttle after reaching certain temps?
His chip can reach 129 deg?
@ts, when u surfing, CPU 100%? Can check via task manager or Ryzen Master.
U have proper antivirus/firewall?
DamShiokla
Ok guys, a screenshot captured using ryzen master app.
https://imgur.com/a/VUNnxDJ
Btw, this was before i ended background app called prime95. In task manager i have checked its 55- 65 temp. After removing it, its around 10.
btw, can background apps cause the spike to increase drastically?
https://imgur.com/a/ySqEV0f <- an image captured using task manager
The only issue that causes the spike is background app called prime95.
DamShiokla
nope, i do not have proper antivirus/firewall. I only used adblocker and ccleaner sometimes.
i have just checked its less than 10 on task manager and on ryzen master. please recommend me on the anti virus/ firewall software. Thanks.
https://imgur.com/JQPvWrd <- current ss from ryzenmaster.
elmariachi
Check that your stock cooler PWM wire is correctly connected. A wrong connection can cause the temps to spike or give a wrong reading.
Rashkae
Prime95 is not a "background app", it's a CPU stress tester. Remove it.
Rashkae
42c is good and normal.
You should consider bitdefender if you want an all in one solution. Or just stick to Windows Defender and Windows Firewall
Rashkae
i cant seem to find that in my control panel. Only see that on task manager. Will it reappear again after my next boot up?
If you have CCleaner, remove it from the Startup option. Or:
http://www.uninstallapp.com/article/How-to-uninstall-prime95-64-bit.html
watzup_ken
The temp is certainly abnormal. I've used a Ryzen 7 2700 before, and even with a low profile cooler, surfing net should not see the temps anywhere near 60 degs.
You should definitely check the cooler mounting, if the cooler fan is connected to fan power connector, and lastly, if the fan is restricted from spinning or not obstructed from pulling air in.
SkyShroud
if everything is in order
properly mounted heatsink (with thermal paste) and spinning fans
thermal paste are not put excessively aka surrounding of socket (and the center of socket) are clean
cpu on idle, less than 5% cpu load
have casing fans installed, one front one back
i would suggest to send the mb for servicing, might be sensor broken
kimsix
I thought TS already solve the problem because his p95 somehow auto-ran in background every startup.
