CPU temp too high?
Koenig168
The default Haswell voltage is set rather high. You can safely lower it a bit and this will give better temps.
I run my 4790K at 3.6 GHz 0.936V and my temps do not exceed 60 on load.
artemov
Sorry, are you are talking about the 1.140V or the 1.153V one in my screenshot? How much should I lower it to?
Koenig168
CPU Vcore. As to how much you can lower it, it differs from CPU to CPU. Lower it until the system becomes unstable and then bump up the voltage a notch.
monikernemo
I disagree with this observation because voltage also varies with architecture? Skylake can run a higher voltage and Haswell seems to be hotter
Ok I'm confused ... so should I get another cpu cooler?
Or just leave it be?
You can continue to monitor first. Generally if CPU temp is around 60-70 deg it is still okay, no need to change. If you want lower temps while gaming, recommend you to change. I don't think at 60-70 deg will affect the life of the chip though.
Koenig168
I was referring to the default Haswell voltage and made no comment on Skylake. To be clear, this meant the default Vcore in BIOS.
wacko
well, at default voltage the CPU should not be running at 100C, Prime or otherwise. clearly something is causing this for TS, could be degradation of TIM, excessive dust accumulation, etc.
wwenze
My response to some posts in this thread:
