Crashed Thumbdrive Solution??
enghwee7
Hi All,
Need some advice, my sandisk thumbdrive died on me recently. Brought it to Sim Lim for data recovery but all shops cannot recover after doing a scan, saying most likely the chip is damaged.
One shop offer to send to some recovery lab for me, 100% can recover but cost will be minimum $500.
Is that my only choice or is there anyone that have solution to my problem?
Would appreciate your help as there are some important work-related document.
Thanks in advance!!
Rgds
wwenze
Flash drive undetected = gg no re
It's worth trying to operate it under colder or hotter temperature though. Try colder first.
yusoffb01
Use recuva (free). If cannot then move on with life and learn to backup
