Creative soundblaster E1 USB DAC
tekster
wondering how will this E1 compare to this DAC..
The E1 u showed is useful only for laptop?
86technie
Thanks for the feedback, Bro! We will take a look at this matter. ;)
Sweet, if you really can carry this Creative portable DAC
more people will be buy higher end headphones.
Let me know when you're selling so I be the first
customer to try. :D
doki81
btw where was this ud120 mentioned? couldn't see it in his blog nor fb...
from lowyat.net forum...the owner post the teaser at his sales thread... :)
you can use it on laptop..but it will also work with some android hp which you can use otg cable on it...
too bad i didnt own any of the UD series before..cannot experiment it yet....
weng
oooo.... ok looking fwd!
cococsharp
Managed to test my soundblaster E1
After initial charge, i opened and tested the item at this moment.
Paired the E1 with my xiaomi pistons and ipad as source.
Played some tracks from spotify.
Tested a w tracks and i'm glad my sound signature has changed a little. When using only default pistions, the sound seems a little flat. After pairing with the E1, the sound seems fuller and has a warmer sound signature to it.
With the default earpiece only, the sounds from various instruments sounds a little off balance. Eg drums sounds further back while the keyboards sounds more in front. But after pairing with the E1, the instruments seems to be more balanced.
Anyway cheap hoot from Creative via their online store. $29 a piece (registration required for the offer).
I managed to buy when the price is $29. From my experience, the sound amplification when I paired with iPhone 5s blown me away. I also pair with iPad Air but the experience is not so exciting as pairing with iPhone 5s.
pilotsnoopy
no more reviews?
i have the E5 but yet to fully try it out.
the E1 and E3 size is much better though i feel...perhaps good enough compromise in terms of size and performance.
chaud@sg
Anyone know where can i try out the sound blaster E1 physically in singapore? Interested in getting one.
jace88
Old thread but I was looking at the E1 today at the PC Show for $49 and it looked decent. You could try it there if you brought your own headphones I suppose. I ended up trying out the E3 and E5 and ended up buying the E5 since the price difference not much.
