Current Graphics cards by pricing.
AS1
wah
i only see 6xxx radeon series
i'm still on 4850. i guess next pc show if got offer means its time to upgrade liao
In a couple of weeks, should be 7 series already. AMD will make announcement about 28mm Radeons on Dec 5.
wtfh4x
faints. asus palit all over.. like chunks of data. unprocessed information.
scrolling up n down non stop ~_~
Just press CTRL+F and the first two digits of your price range lor. Like eg your range is $240-275 then CTRL+F and key in 24. Then repeat but key in 25, 26 and 27 instead.
RadEoNic
wah lan, have school, graduation and working life made me so obsolete?
AS1
I also wanted to add warranty length as well but i guess too much info to process. The user should be able to get the info with a quick search anyway. Quite surprised though that brands offering 3 years warranty not much price difference against those with 2 years warranty in various segments.
rollbread
Among these 4, the difference in price is quite small, but is there any big difference in terms or performance among them? Or just grab the cheapest will do?
LEADTEK GTX 560 1024MB 243
PALIT GTX 560 1024MB O.C DDR5 249
PALIT GTX 560 Sonic Platinum 259
PowerColor ATI HD 6870 1GB PCS+ 259
AS1
It depends. Palit and Powercolor is 2 years warranty while Leadtek gives 3 year warranty. Performance wise, some of the graphic cards are overclocked from factory so perform slightly better then stock but then if know what you are doing, can push performance of stock cards to their overclocked counterparts.
AS1
Still got plenty of Batman to redeem from what i heard.
How many got BF3 LE and how many got the normal one?
AS1
Will add the Zotac 560 Ti once i get the pricing.
AS1
updated AMD/ATI 13/2/2012.
Will update Nvidia tonight because i heard there might be some price revision today.
AS1
Quite surprising from Nvidia side...there were a few the prices actually went up. But mostly the more hardcore ones went down slightly.
AS1
An update for the newer generation of cards.
naked123
sapphire hd 7870 2gb ghz edition OC then ish $499
standard one ish $483
SolarBurn
nice AS1 bro!
can i suggest u use google spreadsheet? easier for u to update =x
