data transfer using wifi (pc to pc)
veltix
So example after getting my new rig, from sls. I wamt do a data transfer via wifi to my new rig. Is that possible? Such as game data/program. ( Game data that's install in c:/programx86)
MoneyFace =p
For newbies like you use thumbdrive transfer sua....
Definitely doable but i don't think you should do it given the need to change many settings, etc...
uniquely_ad
You are so right lol..i used to do Ethernet cable and connect peer to peer to transfer file..without thumbdrive..the trf speed was fabulous
uniquely_ad
Nowadays you wanna do anything, just google
localITguy
Suspended
Easy and fast way, plug the hdd into your new rig and copy to from ur hdd
MoneyFace =p
Yeah i also find it troublesome to keep changing IP address back and forth when switching between PC to PC and normal to router connection. Homegroup since Windows 7 made things much easier but bringing items over still need to create folder and share, which can be still confusing for newbies..
kandinsky
Set up a network, should work. Depending on the amount of data, might be slow...
The easiest way to share files on your network is to set up sharing with a homegroup. If you don't have a homegroup, you can share files by placing them in one of the Public folders. Any file or folder you put in a Public folder is automatically shared with the people connected to your network.
http://windows.microsoft.com/en-sg/windows/setting-wireless-network#1TC=windows-7
micheloving
If both r connected to same router can easily setup network sharing .
There no direct wifi to wifi sharing in windows that I know of .
coyote
It will be even much easier with WiFi Direct but doubt TS have Windows 8/10 and WiFi direct compatible wireless adapters on both PCs...
Assuming he has a good 50G of data, good luck transferring over WIFI....
