DBS changed its Mutiplier plan
andymarsh
1) 50000>25000
2) Dividend becomes income instead of investment. No more SSB ladder liao
Time to switch I guess
jackieatbtu
Invest saver got four different etf. So if want to switch every year, only need to sell at the fifth year for the first one and restart again. Then again, who knows what will happen to multiplier before the end of fourth year. I currently already have the original two etf from years ago. Will start with the newer MBH or Reits one.
cassowary18
Can I read that since dividends will be going into income category instead, salary is no longer needed come Feb ? 🤷*♂️
Edited .. dammed look like they need salary as well
No need. Either/or
That being said, if your passive dividend income can hit 2k...
Guojing88
Sigh, only up to 50k, they also want to play punk.
Just saw that multiplier ad in the cinema too!
cassowary18
Eh, don't anyhow invest especially if the ETF don't match your investment plan.
andymarsh
Yalor. Actually the 3.8% interest not that exciting at max 25000sgd. Just put your money elsewhere to yield interest/dividend/etc. No need to fall in the trap of maximizing multiplier
ahbengsong
No need. Either/or
Pardon me if wrong as I am quite new to multiplier.. Why is there a need to hit 2k in income category since no minimum is needed in each category so long as total transaction is >S$2K or more for higher interest ?
5408854088
OK, now that I've had some time to process what has just happened and think of a new plan, here's my new strategy. Lao jiaos here please share your wisdom, thanks.
Now that the SSB ladder does not fulfill the investment criteria anymore, I'm planning to use Invest Saver to fulfill this criteria instead. My portfolio consists of two local ETFs that are available on Invest Saver. To keep this simple, I'm just going to call them Counter A and Counter B.
My plan is to do this:
Year 1 (currently ongoing): DCA into Counter A using POSB Invest Saver
Year 2: Terminate Counter A RSP, DCA into Counter B
Year 3: Terminate Counter B RSP, DCA into Counter A again
Year 4: same as Year 2
Etc...
Questions:
1. My understanding of the Terms and Conditions is that this will fulfill investment criteria, correct?
2. Do I have to sell all my Counter A at the start of Year 3 in order for my Year 3 RSP to count? This is because of the following line in the Terms and Conditions:
So I'm not sure whether I'll have to sell my Counter A (ie redeem the RSP) for it to count.
from FAQ
Q11) Can I terminate my existing Unit Trust Regular Savings Plan or POSB Invest-Saver and re-purchase so they will be recognised?
If an existing Unit Trust Regular Savings Plan or POSB Invest-Saver is terminated and repurchased within 6 months from the date of termination, the re-purchase will not be considered an eligible transaction.
Additionally, any re-purchase of Unit Trust Regular Savings Plan or POSB Invest-Saver which has been previously terminated but not fully redeemed will not be considered an eligible transaction.
Q12) How can I continue to have my Investments recognised after 12 months?
You may consider taking up a different fund within the same asset class or different asset class.
5408854088
from their web page.
No minimum salary credit or credit card spend
No minimum amount needed for any category as long as your monthly total eligible transactions add up to S$2,000 or more. That’s our promise so you can Do Less, Multiply more.
1scape
when is the latest date i need to invest in invest saver for it to be effective in feb?
5408854088
Sell everything of the one counter or all the counters?
What!! Sell everything.. I :(
only sell everything of that counter. or just get UT when you have maxed out the 4 ETF. there is a list of UT eligible for RSP.
ahbengsong
Thanks ..I am planning to switch salary back to BOC if it is clear dividends will be counted as income
a4973
hi thread members, which is an appropriate ETF / UT via RSP to fulfill the Investment criteria with capital preservation + maybe 2% PA yield ?
thanks
