DBS changed its Mutiplier plan
5408854088
yeah in that case. unless you only have 1 cat, the changes shouldn't affect you right. it could make it even better, no?
u can now move your salary credit out and let dividend take over for the income req.
correct. but the different tiers of total eligible transactions per month will still be there. unless your dividends on a monthly basis is as much as your salary credit, it may not be wise to move out the salary credit. unless the person is aiming for the lowest tier of less than 2k worth of transactions per month.
xfactor
Personally, I'm keeping my SSB ladder. I don't need that $3k for now, no point incurring that $12 fee, and it's a backup for the Income category if I ever decide to move my salary crediting elsewhere.
现在我可以 change 我的 salary credit to 其他 bank 了
5408854088
from their T&C
3 ELIGIBILITY OF TRANSACTIONS
3.1 Only eligible transactions described in Clause 3.2 below, taking place from the date of Multiplier Account opening, will be considered (“Eligible Transactions”). However, if the Multiplier Account opening happens on the last calendar day of the month, transactions will only be taken into consideration from the following calendar day. Eligible Transactions will be
computed daily for the full calendar month only (i.e. the first to last day of the calendar month). Modifications to the calendar month of which an Eligible Transactions was recorded is not allowed.
3.2 Only Eligible Transactions qualify for computation of the higher interest. In order for transactions to be considered Eligible Transactions, you must successfully credit your income with DBS/POSB in accordance with Clause 3.3 below and additionally make transactions in any of the 4 categories of transactions listed in Clause 3.4 below.
3.3 Income
3.3.1 Salary Credit
(a) Salary must be credited via GIRO, using transaction reference codes of SAL or PAY, into any of your personal or joint DBS/POSB SGD-denominated savings/ current accounts.
(b) Salary credited must be reflected as either GIRO Salary or Salary under the main transaction description in your Statement of Account.
3.3.2 Dividend Credit
(a) This must be credited via Central Depository (CDP) into any of your personal or joint DBS/POSB SGD denominated savings/current accounts.
(b) Dividends from Singapore Exchange (SGX) listed companies credited into the Multi-Currency Settlement Account (MCSA) are also included as Eligible Transactions.
shingo86
No pt keeping ssb ladder if dividend cannot yield more than 2k in value.
And if the ssb is below 1.9% interest for the next 12 mths.
Personal opinion.
Sent from Xiaomi MI A1 using GAGT
vegavega25
Surely their next move will be introducing a minimum for the credit card transaction category.
kurt111494
Omg is this true? I building the SSB ladder half way only
You're not alone. Going to stop buying for the ladder and move funds out to leave only 25k behind.
Worst case, I'll change bank completely and credit salary elsewhere.
sansanjikikut
you mean now dividends is compulsory under income category? i thought it was either salary and/or dividends. and the dividend credit monthly from ssb only like < $5 per month, assume u only did the 500/mth for 6 months.
BlackCube
correct, but if you are using dbs cc, then this could help to achieve > 2k transaction. assuming if you using quite abit monthly.
think this one whether good or not quite dependent on individual usage pattern.
sansanjikikut
you are one of the minor few who will do so. dbs know customers won't tend to move funds due to present inertia, and the "trouble" needed to change salary credit account in their company :s13:
yiron
Yea, I'm surprised they haven't done that thus far, but maybe that's how they differentiate themselves from other high yield savings accounts which typically comes with a credit card min spend component.
I don't favour DBS credit cards (mile chasers may be fine though, since they have WWMC) so that might be the cue to make me move out.
Project_Xco
Btw those who open joint account where salary credited in + 1 credit card spend (each) will be able to enjoy additional interest up to 25k for both accts? (ie: 25k x 2 = 50k)
yiron
Dividends is not compulsory - you can check off the Income category with either salary or dividends.
chiokcc
25k is the cap for 1 cat. To summarize:
Salary (more accurately speaking, it's income now, which is either dividends or salary) + 1 cat: bonus interest capped at $25k
Salary + 2 cat: bonus interest capped at $50k
Salary + 3 cat: bonus interest capped at $100k
Is this $25k-50k-100k tier announced? I could not find it...
tangent314
Moderator
Moderator
There's no real reason to panic.
For the first year of the multiplier plan I have RSPed $100/month into G3B. For the second year of the multiplier plan I move the RSP into A35 while setting up the SSB bond ladder. Now that MBH is available, I will move the RSP to that.
Next year? I'll worry about that when it comes, but I have the option to switch to that new REITs ETF though I don't quite like that or just one of the many UTs available. Or I may redeem my A35 and G3B 6 months prior and then switch back to that.
