DBS changed its Mutiplier plan
ixoral
RSP (investsaver) deduction is every 15th of the month. So this criteria will only work for u in August
Only thing I can think of is that I bought RSP on 16 Jul. would it count for this month? Since it hasn't been a full month since
I definitely bought the RSP after opening the account, so I should at least have salary + 1 category
LuckyPockets
My salary is also using GR code, so that's not an issue.
So how do they calculate the interest anyway?
(Amount in bank X percentage)/12, and this is calculated every month?
Buzy_bee
Yes. Only the balance in dbs Multiplier account is taken into consideration in the interest calculation.
Perisher
Deluxe Member
If every month there are dividends coming in to my posb account, not the multiplier account, does it count?
The dividends are from other brokerages but credited into POSB savings account. It’s from cdp crediting.
From what I read off the faq, as long as it’s cdp into dbs accounts it should count. :s11:
chiokcc
Counted as long as your POSB acct is the reference acct, which should also be where your salary is credited.
I buy/own different share counters to ensure I have at least one dividend coming in per month to satisfy the "investment" component.
Trazora
what reference acct? thought dividend across all his posb/dbs account will count
Perisher
Deluxe Member
Huh? Thought salary crediting must be to multiplier so don’t need also?
chiokcc
Oh OK. All my transactions (SAL, CDP, etc.) are done in only one DBS/POSB acct, so I only have "experience" with one "reference" acct ....
superguy276
Interest
Hi, how much did you all receive for the 1.9% tier for 50k ADB. the interest seemed slightly off. Receive only around 60sgd instead of around 80sgd. Anyone got same problem?
zSpiraL
Mutiplier bonus interest not based on ADB. Bonus is computed daily based on 50k in account. Daily bonus interest is then sum up.
oinkoink1999
Not sure if this qn has been asked before, is joint ac counted as total deposit for interest computation?
Sent from My UNDER ARMOUR UNDERWEAR using GAGT
a4973
Which means if even 1 day less than 50k cannot make up by depositing more than 50k for a few days right?
Sent from Motorola NEXUS 6 using GAGT
Slowdown
The best to do with DBS Multiplier is to treat it as an dormant account. Put 50K inside and don't touch it. As mentioned by others our salary does not need to be put into this acct. My DBS Multiplier acct do not have any transaction posting other than the two interest payment coming into the acct.
I don't even bothered to take out the interest. I am planning to take out the interest once a year making this acct acting like a FD.
