DBS yuu credit card
twosix
Only suited for those who spend at the merchants, so a bit more niche of a card.
I only consistently use 1 of the mechants, so for me it's not worth the hassle to have to worry about the other 3.
yes, those who will use this card is already doing that. so to stop using it just because need to spend at 4 different merchants now, is kinda giving up a lot of savings or miles.
example, spend 5c to buy a plastic bag at the other 3 merchants.
sglandscape
Provided the other merchants are conveniently located where you stay. But that's a good tip!
lucky_
Just wondering cos i have a couple of upcoming trips - is the 18% rebate application overseas e.g. Gojek / Guardian in other countries? I dont think it was in the tncs
Trazora
TnC specify Gojek Singapore, not sure for Guardian
louist
Don't see this being discussed here yet… Bread Talk grp appears to be exiting Yuu from 27 Oct. It's no longer on the PAssion POSB Debit Card page, but you can see it within the Yuu app when you visit the affected merchants (e.g., Bread Talk, Toast Box)…
