Hmm. your annual income 66k means your monthly is $5,500 correct?
If your outstanding is $60,000
Your BTI = $60,000/5,500 = 10.9x
With $60,000 outstanding, you don’t qualify for DCP
With 5% buffer, you still are at $63,000/5,500 = 11.5x. Still don’t qualify.
If your outstanding is $66,000
Your BTI = $66,000/5,500 = 12x exactly
With $66,000 outstanding, you qualify for DCP.
With 5% buffer, you still qualify for DCP.
I’d suggest you to calculate your outstanding carefully and be sure of the total outstanding you have currently.
Also, how recent is your CBS, BB is VERY good, but does not exclusively mean your DCP will be approved. Not necessary to know your rating number since you’re a BB. Should be 1.9k+
Thank you for the advice.
I shall check my total outstanding first.
Heard so far the best rate longes period is dbs , is it correct?
