Anyone can help me customize a good gaming pc? Don't want gigabyte , pls help
CPU: Asrock H81M-HDS + i5 4460 ~ $320
RAM: G.Skill PC 12800/1600MHZ DDR3 CL11 Value Ram (8GB) ~ $98
GPU: Sapphire R9 280 3GB Dual-X ~ $285 ~ get from Lazada
SSD: Plextor M6S 256GB ~ $175
HDD: Toshiba 1TB 7200Rpm ~ $69
DVD-RW: LG 24X DVD-RW SATA OEM ~ $25
PSU: Superflower Hx 600M Gold Modular ~ $109
Case: Deepcool Tesseract ~ $65
OS: WINDOWS 7 HOME PREM ~ $125
Total ~ $1,271
Get the parts from PC Themes unless stated otherwise.
Buy the GPU from Lazada on mondays to get 10% off!
Self DIY and engage PC Themes to fix for a nominal fee
sorry no offend , if u really wan game get at least a r9 280x above , used one easily at $230 . anything below that i feel lousy gaming , if u buget enough buy gtx 970 so later u wont regret sell and buy again
GTX 970 cost?
Really no idea for about GPU, too many brand, scare get a lousy brand like gigabyte
gigabyte i didnt use b4 but only heard noisy but fast n cool . msi i did got a artifect problem one but is a Ati card so duno is software or hardware issue . Only Asus never had give me problem . Anyway nvidia is mostly no issue , Amd is cheap and good but still have some software problem
If get a normal mobo, can support a good graphics card ? Like the msi h97-pic mate
The problem is I need that PC on tomorrow
Any good recommend shop intro ?
Actually I got some idea,
MSI H97-PC Mate LGA 1150 Motherboard
I5-4690
Sapphire R9-280x 3gb vepor
Kingston hyper 1866 8gb x 2
Casing no idea,
Thematek 750w 80 gold
What is msi GTX-970 4gb oc
Hey shin. Want to point out that price diff for i5 4690 is not worth the minimal performance over 4460.
Motherboard a as rock b85 is good enuff. A h97 is only useful for raid. Psu 500w enough. Is just wasted money you could be spending on what matters most, a graphics card. I highly suggest a 970 of any brand other than evga. Also a ssd if can.
