Lampard
Hello experts, I need some advice. My motherboard recently died, and I’m considering an upgrade. I bought this rig about 5 years ago for gaming, but now I'm no longer gaming and mostly use it for office work and downloading movies. I took it to an SLS shop for testing, and they confirmed the motherboard is dead, but the other components are still fine. I’m exploring a few options and would appreciate any suggestions on what would be the best course of action.
Option 1: Get 2nd hand B365mb through TB or carousell ($50-$70)
Option 2: Selling everything and get a cheap entry level rig ~$500
Option 3: Replace just cpu+mobo (maybe ryzen 5 4600g + asrock b450m-hdv r4.0 ?) and reuse everything
Current setup:
I5 9400F + Asrock B365m pro4
2 x 8gb klevv ddr4
Zotac RTX 2060
500gb m.2 ssd + 1TB 2.5hdd
Evga 500w2
NXZT H400 casing
tales23
First off, thank you NightRaven49 for still keeping this thread alive. Whilst it is not something that I frequent often, it is by far the most important if and when I need some advice on my PC.
I have been using mine for around 6 years now. Specs as follows:
1. Intel i7 8700
2. Asus TUF B360-Pro Gaming/Wifi (gave some problem in the warranty period and was eventually replaced with a new one)
3. Nvidia GeForce GTX1080ti
4. G.Skill Ripjaws V2666 Mhz CL15 (8GB x2)
5. Samsung Evo 970 M.2 500GB
6. WD 4TB Blue (5400 rpm)
7. EVGA G+ Series 650W
My GPU is currently giving some problem due to only having one port working, which limits me now to using 1 monitor. I have not much issue with my PC generally as the things I do can be served by the current spec. However, if I were to now get a new PC, is there any recommendation for one in the region of SGD 1.5k? I am always looking for value and as can be seen above, logetivity is most appreciated. Also, is there any part that I can use from the existing PC in the new PC?
Thank you in advance to whoever providing kind advice.
deepblue_82
Current setup:
2 x 8gb klevv ddr4
Zotac RTX 2060
Evga 500w2
NXZT H400 casing
if u are not planning for gaming anymore... then for me i would go for 4600g+450m coz that is only 200+
deepblue_82
1. Intel i7 8700
1. out
2. out
3 out
4 out
the rest can reuse
should go for amd am5 but are u planning to game? if u are playing to game u can go for a x3d chip if not then u can go for a non x3d chip
then what card are u looking at? if u gaming then should wait for the next gen like really around the next bend
if u are not gaming then u can look at current gen but only on sale...
NightRaven49
i think option 3 is best course of action, since u get brand new parts with local warranty and u can still reuse ur existing ddr4 ram. since u were already using a 9400f without integrated graphics, u can save even more money while getting a more performant cpu in the 5500 (techdeals has the 5500 combo $22 cheaper than the 4600g combo). getting a used b360/5 might be the cheapest way, but the longevity would be a question mark.
can refer to first post for the enthusiast reco. but if u dont mind prebuilts, u can get a similar rig from system integrators like invaderpc for much cheaper.
NightRaven49
tk
both are functionally identical. the parts on offer are not particularly great, though invader does offer a wider range of upgrade options, then again aftershock is the outright cheaper choice. depends on which u value more.
The specs are similar, so I guess the choice is more on which retailer is more reliable and whether Gigabyte or Asus is better.. I'm a bit out of touch so trying to gather some of the expert opinions here..
tysden
nightraven got put this up at page 1 and i belive 1 member on the previous page did the sme build as well.
entry level 1080p low gaming pc, total: $471
ryzen 5 5600g + asrock b550m wifi se277techdeals
gskill ripjaws v 2x 8gb 3600c18 ddr452tradepac
adata legend 710 512gb52pc themes
fsp hv pro 550w50pckaki
tecware nexus air m240tradepac
Thank you @Bardiel
I saw the 1st post and thought that it was not updated since posted date Dec-2022, is my mistake that did not realized that it had been 'updated' (edited) on 19-Nov-2024.
I will definitely look into the proposed "entry level" parts set. Questions,
1) What if I do not need the "Wifi & Bluetooh" option for the MB, is there another b550m model option that is without them? As pc will always connected to Lan and also I already has a Bluetooth adaptor (maybe price is cheaper).
2) Does the Techware Nexus Air M2 casing comes with power supply? As I saw the "fsp hv pro 550w" is listed part of the set.
And does this casing comes with the 'fans' (2x front, 1x rear)? I read online it has the 3 fans.
3) Below list is my existing (still) working parts, about 6 years old. Can the Ram & SSD be re-used, or recommended to get new ones?
  • Intel G5400 3.7GHz 4MB LGA 1151
  • MSI H310M Pro M2 MB
  • Kingston 8GB PC2400 DDR4-DIMM (1pc)
  • Transcend 240GB SSD
Thank you in advance for advice/answers.
tysden
u can also buy this
https://www.invaderpc.com/product/specg01/
if u lazy to build and upkeep
pay abit more for warranty...
Thank you @deepblue_82 , for sharing this alternative option. Will put it into my overall consideration.
Comparing this set from Invaderpc to the DIY set in below table, if putting aside the DIY manual work requirement and price difference, which set is better?
NightRaven49
i feel brand doesnt matter as much when looking at the entry level offerings.
both b550s have quite a similar feature set; the asus board offers full 4 pcie3 lanes for the secondary m2 slot opposed to only 2 lanes on the gigabyte, while the gigabyte board trades 2 usb3s for 4 usb2s on the rear io and has a slightly better power delivery solution (though still not great). for use with a 5600 though, the latter point is moot.
ddr4 has matured to the point where unless ur looking to tune for crazy tight timings, any kit will do fine for general use.
both psus are also just ok, though invaderpc does at least offer a somewhat affordable upgrade to the better quality silverstone et750g with 2 more years of warranty.
both ssds are qlc based and generally expected to be quite meh, though the p3 plus on invader is more widely reviewed and known vs the nq700.
the biggest difference would be the gpu choice, where the asus dual runs way cooler and quieter than the gigabyte windforce.
it seems to me the sama case from invader would be pretty good for airflow too, with 3 fans behind a mesh intake, while aftershock prefers an all exhaust setup.
ive heard quite a few horror stories regarding aftershock qc and customer service, though that could be attributed to it having a large brand presence in sg. they also only cover 3y of hardware warranty, which for some parts like ram and ssd is a shortchange as they can get 5y to lifetime warranty. invaderpc isnt perfect either but at least they give u the full hardware warranty from my understanding.
the non wifi b550m pro se isnt available locally, but u can opt for other motherboard models. for basic usage like urs, any am4 motherboard will do fine really.
the case and power supply are usually separate unless specifically mentioned. power supplies that come with cases should be avoided in general as they are usually quite cheap and low quality.
the nexus air m2 doesnt come with a power supply, but it does come with the 3 fans like u mentioned.
u can, since ur just using it as a general work/home pc, so the faster ram and ssd will not improve the experience drastically. even if they spoil, replacements are quite cheap. imo 8gb of ram isnt quite enough nowadays though, so u could get another stick of 8gb ram to just add on, but not strictly needed.
u can also consider cheap mini pcs if u dont need the upgradability and/or indifferent to diy.
u save maybe $50 vs inavderpc, which can be largely attributed to the halving of the storage. if u top up maybe $30-40 to match the 1tb storage on the prebuilt, i think that premium is well worth it for the convenience and support going invaderpc if diy is not ur thing, since both builds are very similar otherwise.
Bardiel
actually ui can consider a mini pc too. since running on onbard graphic as well.
can consider read abit here or the last few pages where ppl recon what can buy.
https://forums.hardwarezone.com.sg/threads/mini-pcs-2023-any-good.6859514/page-26
sacar101
For PSU at least get a 80 plus bronze. As NightRaven49/Bardiel recommend, you may consider mini pc. If you willing to pay a bit more, rog ally also not a bad choice.
deepblue_82
diff being ssd space u will need at least 1tb in the long run.
warranty is there so u can close ur eyes and use for a year or 2 depending.
of coz if u are willing to warranty the single parts alone then diy is the way to go.
i also would get a better 550w psu
Bardiel
Thank you for your advices, @NightRaven49 , @Bardiel , @sacar101 , @deepblue_82 .
For the casing, I like/prefer the DIY "Tecware Nexus Air M2" compare to the pre-build model from Invaderpc.
Does anyone know if Invaderpc take request to change the casing type for their pre-built set option?
what specs u looking at? u can also WA Dynacore based on what u want and let them quote u.
taiji84
Hello all, just wana check, if i was to use a ID Cooling Frozn A410 TDP 220, can cool a Ryzen 9800x3d right?? And my Ram 6000cl30 can support it with no issue or will need to upgrade to 6400cl32?? abit tempted to get the 9800x3d even thou i just got the 7600 not long ago..
ObviousToast
Anyone has recs for the cheapest 16gb vram gpu and where to find them? Need it for AI use so Nvidia is best. Currently have a ASUS RTX 3060 12gb, wondering if I should get another one or would swapping for a single 16gb would be better
NightRaven49
in games, it should consume about the same power as a 7600 actually, so if ur current temps are fine then u wont need to upgrade ur cooler.
ya ur current ram enough, in fact "upgrading" to 6400c32 may actually decrease performance as u will likely have to run ur uclk and mclk at a 1:2 ratio, depending on how high u can run ur uclk (silicon lottery). x3d ryzen is significantly less memory sensitive to ram speeds compared to non x3d, u could even get slower cheaper ram and not lose a whole chunk of performance, so i dont think u need to worry much about ram.
outright cheapest is 6800 non xt, can get used on carou for less than 400. if prefer brand new, got 7600xt. for nvidia side will be the 4060ti 16gb.
