Thanks all for your responses!
Does this mean the 7500f+9060xt may be the best option out of the 3? Or is the 225f+5060ti still better?there is a 7500f + 9060xt 16gb pc they are offering for $10 less than the 5060 build above. the 9060xt is very comparable to the 5060ti performance wise and still offers the 16gb vram capacity which will help in keeping it usable for longer. the 7500f and 7700 are also quite comparable in gaming while being a tier faster than the 225f in cpu limited gaming.
Yea, I know they give upgrade options, but the difficulty is that I don't know whether a particular component is better or not.invader should be able to help u upgrade almost anything on their checkout page other than ram and ssd (for unfortunate reasons), but even those are simple enough to diy. u can consider psu upgrade like networked mentioned, something like the silverstone et750g would be ok for a slightly better quality unit but not strictly necessary given the low overall power consumption.
kinda depressing to see these used to cost a lot closer to $1k last year though![]()
