yukita
- Jan 1, 2000
how large is your zotac? For CH 260, a 16cm can actually squeeze in if your gpu isn't too long. I was using a 16cm full ATX PSU on the CH270 plus for the longest time before i bought a SFF PSU
Zotac card is 303.5mm x 115.8mm x 55.7mmMost PSU is 160mm x 150mm. I tik u shld try fix 1st. U r not using iTX casing. shld be able to fit.
I think both of you are right, when i look at Lian Li, I look at side mount PSU config, this cause the GPU length support only 258mm. but if i mount front side. it support 334mm.
For CH260, already mention max PSU is 150. because its side mounted, i think this one no hope unless change PSU.
For Jonsbo, it is stated:
ATX PS2 PSU Clearance:
• When the GPU is installed in the first PCI-E slot of the chassis, the maximum length of the power supply is 150mm, and the recommended length is ≤140mm
