blammer
heya i'm thinking of upgrading my mobo and cpu and reusing my older stuff. Usage is mostly for gaming like darktide/lethal company with mods etc. Would this match be feasible?
ryzen 5 7500f + msi pro b650m-a wifi
gskill ripjaws 2400mhz 2x8GB ddr4 (must i replace with ddr5 ram for the new mobo and cpu?)
zotac gtx1660 twin fan
corsair CX750M modular atx psu
phanteks eclipse p400s case with 2 HDD and 1 SSD
RockaRolla
Yes, AM5 platform is ddr5 only, you cannot reuse your ddr4
nakedtons
Don't mind I ask if Amazon DDR4 Corsair RAM goes bad after just 6 months? My PC has been working fine until about a month ago. Sometimes it is able to post and sometimes it doesn't. I tried troubleshooting and narrowed it down to the RAM. PC is only able to boot with two sticks of RAM and not from the other kit. It sometimes have the rgb working and sometimes it is completely dark. I have no idea which are the faulty sticks. I bought 2 packs of RAM at Amazon at the same time.
deepblue_82
ram is lifetime warranty.. u can send in for rma
nakedtons
The error could be due to this. I made a mistake by buying 2 ram kits instead of 4 in 1 kit while trying to save $150. Not sure if this was the cause of the boot issue. If PC attempts to boot from DIMM 1 and 3, it will not boot. It needs to boot from DIMM 2 and 4 in order to successfully boot. So DIMM 1 and 3 is kind of obsolete because they are different kit. Hope that bros will be aware that if they wish to fill up all ram slots, they should buy the whole 4 in 1 kit otherwise it may cause boot issues like in my case.
Either I forgo 2 sticks or sell off the 4 sticks and buy a new set of 4 in 1 kit.
cyberwave
tried swapping the sticks around to isolate which sticks are bad? could be bad ram slots on the mobo as well
deepblue_82
last time i also tried to boot with 2 set of ram.. 4 slots filled boot failed
2 diff set
nakedtons
2 diff set
Today, i tried with just one stick, still no boot. Different gpu and monitor also no boot. Change hard disk also the same. Worse case scenario is motherboard problem. Just used 1.5 year, failed so fast? :cry:
deepblue_82
this one really is luck... just send in for rma...
deepblue_82
If it's motherboard, then need to rebuild everything.:( Same motherboard version still need to reinstall everything after rma?
if i am not wrong if u clone ur hdd or ssd no need to reinstall...
last time i send my system to nigel to repair my mb gg......... i got back fully the same..
ragnarok95
Senior Moderator
Senior Moderator
Best to reinstall even if change to the same mobo. Anyway now installing window 11 is quite fast on the NVMe drive. Slower one are the apps and games. But for me, i rather start fresh anew.
nakedtons
Can I request for the service centre to help me flash my bios and test it on the spot?
nakedtons
If there is no issue, I'll just stick to the same OS and apps on the newly replaced mobo. I have lots of apps, files and games. Might need about 2 hours to reformat, reinstall everything and transfer everything from backup hard disk.
