DIY PC Rig Recommendations For 2026
deepblue_82
z790 is better if only u are planning for pcie5.0, overclocking and need more ports and slots if not there is no other reason to choose the z790 over the b760
and if you are rich... jkjkj dont shoot me
Purplestars
which shop can go and have them help me assemble my parts? How much will it cost?
Will they install unactivated windows for me?
BiggieZee
For M2 2tb, im down with this few choices - wd sn570, Samsung 980 n lexar nm710. Price difference is $8-10. So which one is good? The lancool 216 case selling for $125 at pcthemes fyi
Purplestars
is the GPU really more important than the CPU for flight sim / p3d? Feel like buying a higher end CPU and just go cheap on the GPU with 4070
godspeed2000
Currently debating Ryzen 5600 + RTX 4070 build for ~1600 vs a Ryzen 7600 + RTX 4070ti build for ~2300. Notable difference in price due to needing different mobo, ram and psu. I'm trying to aim for 1440p 144hz on most games. I'm not sure if the performance difference is worth the price difference, but at the same time I'm afraid the 4070 will not be powerful enough. Can anyone give me some advice?
R6exR6
As a non-competitive player, I'd go for 5600+4070Ti.
If competitive, 7600+4070 ... if cost is an issue.
NightRaven49
Hi guys,
Can help to recommend me a work desktop?
Budget below $1k. No need monitor. Mostly using to watch youtube videos, open lots of chrome tabs and word documents and such.
Probably minimum Intel i5 and as small a case as possible but don't want itx cos more ex. Thanks!
for general office work, the entry level 1080p pc @ $500 is enough, and swap the case for the tecware fusion to make it compact. u can also consider changing the ram to 32gb too. a comparable intel cpu + mobo alone would cost as much as this entire amd rig, so value wise it is not there.
Thank you for prompt reply and advice
Which DDR5 should i chose ?
right now bizgram has a good price for 32gb of gskill ripjaws s5 5600c40 ddr5, as suggested in the high performance rig.
BTW, is it okie to not get zotac and have other generic brand if the shop doesnt have them.
yeah, just make sure u get the 12gb version and not the 8gb.
Hi @NightRaven49 ,
when you mention suggestion for 4k msfs above with about the same performance for quite a bit less are you referring to the specs below?
core i7-13700f + gigabyte b760m aorus elite ax d5791dynacore
arctic liquid freezer ii 360mm162techdeals
gskill ripjaws s5 2x 16gb 5600c40 ddr5145bizgram
wd black sn850x 1tb145pc themes
sapphire rx 7900 xtx pulse *313mm x 133.75mm x 52.67mm1530bizgram
asus rog strix 750w149dynacore
nope, i was referring to this:
ryzen 5 7600 + asus tuf gaming b650m-plus wifi584dynacore
thermalright peerless assassin 120 *157mm height69bizgram
gskill flare x5 2x 16gb 6000c32 ddr5 expo *highly recommended to tune timings195dynacore
zotac rtx 4070 twin edge zotac rtx 4080 trinity oc *356.1mm x 150.1mm x 71.4mm1791dynacore/techdeals
with a $150 case it should total $3083.
had the impression that the Z790 is a better chipset, i think i am probably wrong on this
its only worth it if u have a k/kf sku for cpu oc support, the premium is wasted on locked cpus like the 13700f.
most pc parts shops in sls should have building services, though tiagong if u go to one store with parts from other places they will charge build fee ($30?). not too sure about installing windows.
lexar nm710 sounds good for the performance.
both are equally important but considering that the gpu is the main component rendering each frame it is more likely that u would see a bigger impact on performance with a stronger gpu. 4070 is also barely enough for 1440p60 native on msfs, but if that is the resolution and refresh rate u are targeting then by all means.
4070ti is about 20% faster while having the same amount of vram. by ur estimate, u are paying almost 50% more for the 4070ti for just 20% more performance. personally, i would go for the 5600 + 4070 build and turn down some settings to ensure 1440p144, that price delta isnt worth it to me.
hagty10
Wondering if this rig is good or makes sense. Looking for a PC that can game and handle a lot of tabs and also some AI training/tools.
Current setup is laptop with AMD 7 4800H with RTX 2060 and 16Gb ram that starts hanging when i connect to a second monitor.
Aftershock Rapid,
mobo: Gigabyte A620M Gaming X AX
cpu: AMD Ryzen 7 7700
gpu: Zotac RTX 3060Ti 8Gb
ram: 32GB ADATA Lancer RGB DDR5 6000MHz CL40
psu: 850W Deepcool 80+ Gold
cooler: Deepcool AK620 Zero Dark
ssd: 1Tb Samsung Gen4 SSD
hdd : 1tb toshiba 3.5" 7200rpm
Price ~$2k
jasperchc
Hi guys, planning a new built, can anyone advise if the below make sense?
Gigabyte Amd Radeon AORUS ELITE RX 7900 XTX 24GB
Ryzen 7800X3D + GIGABYTE X670 AORUS ELITE AX
Thermalright Peerless Assassin 120 SE Cool )
G.SKILL TRIDENT Z5 NEO RGB DDR5 6000MHz CL32 16gb x2
Lianli Lancool 216 ARGB Black
Asus Rog Strix 850W 80+ Gold
Samsung 980 Pro Gen4 NVMe M.2 2TB
NightRaven49
@NightRaven49 How do u decide on a MB or GPU alernative when they are always out of stocks ? hmmm
if the one i have in mind is oos, then i would generally just go for the next cheapest option. for gpu doesnt matter too much, but for mb i would also check the vrm capability.
Aftershock Rapid,
Price ~$2k
doesnt sound like good value to me. u can get the high end gaming rig as i suggested and get way more gpu horsepower and vram for ai/ml, while still having a very responsive and high quality system in general for about the same price.
looks good to me.
hagty10
I found one that seems close to the high end rig you posted, have 2 general questions,
> Is the performance of AMD 7 7700 vs AMD 5 7600 vs intel i5-13600kf big or worth the difference in price?
> So would you recommend one out of these 3 or do they all have lacklustre value
Aftershock rapid
~2k
Invader PC Master MK3 AMD 5 7600
- AMD RYZEN 5 7600 3.8GHz 6CORE/12THREAD
- ASUS TUF GAMING B650M-PLUS WIFI AX ARGB
- ID-COOLING SE-214-XT ARGB BLACK 180W
- KINGSTON FURY BEAST RGB 5600MHz 16GB(8GBx2) CL36 AMD EXPO
- ASUS DUAL RTX4070 12GB GDDR6X
- WD BLACK SN770 1TB 5150MB/s GEN4
- SILVERSTONE ET750 GOLD
- MONTECH AIR 100 BLACK ARGB
$1815
Invader PC Master MK 3 Intel i5 13600
- INTEL I5-13600KF 3.50GHz 6+8CORE/20THREAD
- MSI MAG B760M MORTAR WIFI DDR4 AX ARGB
- KINGSTON FURY BEAST RGB 3600MHz 16GB(8GBx2) CL17
$1945
Purplestars
How about this two? For flight sim of course.
I'm still leaning on the first one, not sure if I should save myself $250 and take the last one.
SUPREME MK5​
SGD $ 2,869.00​
Specifications:
- IS13700KF4070TI-WF28
- INTEL I7-13700KF 3.40GHz 8+8CORE/24THREAD
- ASUS PRIME Z790-P WIFI AX ARGB
- DEEPCOOL AK620 ZERO DARK 260W TDP TOWER
- G.SKILL TRIDENT Z5 RGB 6000MHz 32GB(16GBx2)CL36
- ASUS TUF GAMING RTX4070Ti 12G GAMING
- CRUCIAL P3 PLUS 2TB GEN4 NVMe M.2
- SILVERSTONE DA850-850W 80+ GOLD FULL MODULAR
- FRACTAL DESIGN NORTH CHARCOAL TG
- ARCTIC P12-120MM PST BLACK PWM SINGLE PACK
SUPREME MK5 ​
SGD $ 2,595.00​
Specifications:
- IS13700KF4070TI-WF22
- INTEL I7-13700KF 3.40GHz 8+8CORE/24THREAD 30MB
- DEEPCOOL CASTLE 240EX BLACK
- CORSAIR VENGEANCE RGB PRO SL BLACK 3600MHz 32GB
- ASUS PRIME AP201 MESH
- DEEPCOOL FC120 3-PACK ARGB
NightRaven49
in gaming, not very big when using optimal ddr5 configurations. id just get the cheapest out of the 3. however, if u do plan to do core heavy workloads, then the 13600kf will be the obvious choice.
Aftershock rapid
~2k
$1815
$1945
the aftershock rapid with the 3060ti is way overpriced. the invader pcs are better at a lower price, and i would go for the 7600 system for pure gaming, especially considering the 13600kf system is ddr4 and yet is still more expensive.
SUPREME MK5​
SGD $ 2,869.00​
Specifications:
SUPREME MK5 ​
SGD $ 2,595.00​
Specifications:
i saw a previous version of ur post with a 3rd build with a ryzen 5 7600, i think that one was the best deal out of the 3. the 13700kf could be held back by ddr4 and when ur paying this much for a pc, no point saving that money if its going to cut performance.
Purplestars
Specifications:
- IS76004070TI-WF44
- ASUS TUF GAMING B650-PLUS WIFI AX ARGB
- THERMALRIGHT PEERLESS ASSASSIN 120 DUAL HEATSINK
- KINGSTON FURY BLACK DDR5 5600MHz 32GB(16GBx2) CL40
- ASUS TUF GAMING RTX4070Ti O12G GAMING OC
- CRUCIAL P3 PLUS 1TB PCIe GEN4 NVMe M.2
- ADD ON: PWM 120MMX 1 FAN
Really this is the best one? Isn't the less cores and the Ryzen 5 weaker than thr i7? I'm biased towards having a better CPU as my past experience with flight sim was that it was really CPU intensive. Kinda out of touch with how things are nowadays though.
kimsix
Specifications:
- IS76004070TI-WF44
7800x3d is good for flight sim. 4 years local warranty :o
ram and ssd buyed from amazon cheaper.
This supposed good for tweakers :o
https://www.amazon.sg/TEAMGROUP-T-Create-Overclocking-6000MHz-PC5-48000/dp/B0BPHRGLSH/
Corsair got global warranty though they use phison controllers, maybe less reliable long term than crucial own controllers.
https://www.amazon.sg/CORSAIR-MP600-NVMe-PCIe-CSSD-F2000GBMP600PLP/dp/B09Q2NCFS7]
