DIY PC Rig Recommendations For 2026
deepblue_82
Sorry to sound like an a**hole.
But my PC noob friend wants to play D4.
He is completely noob.
So need to find builders.
He went aftershock n tabulated about 3k.
please 3k is very over kill
build and get nigel to fix up for him
mid-range gaming rig, total: $1371
ryzen 5 5600 + asrock b550m/ac316tradepac
kingston fury beast 2x 8gb 3600mhz cl17 ddr469dynacore
wd black sn770 1tb94tradepac
powercolor rx 6750 xt red devil638tradepac
super flower legion gx pro 650w104techdeals
anibit
Hi everyone. So I'm planning to buy my first ever pc this weekend at SLS. These are the components that I have picked.
Would like to know if it's a good build and if the CPU cooler would fit with the MOBO.
Planning to buy everything at Tradepac.
CPU+MOBO: ASROCK Z790 PRO RS WIFI AX +i5-13600KF
$733
CPU Cooler: Thermalright Peerless Assassin 120 SE Cooler
$55
Memory: ADATA XPG LANCER RGB DDR5 6000MHz CL30
$205
Storage: WD BLACK SN850X NVME GEN4
$130
Video Card: ZOTAC GAMING RTX 4070 TWIN EDGE 12GB
$863
Power Supply: SEASONIC FOCUS GX-750 750W
$181
Case: Lianli Lancool 216 ARGB Black
$125
Total: $2242
Daty41
3k is way too much for just d4, u can build a top of the line system with that kind of money (see high perf productivity + gaming reco). for 1080p and even 1440p, can reference this post or the value gaming pc reco. for 4k, the midrange reco enough. u can take a look at this article for an idea of the requirements at the resolution and refresh rate ur friend is targeting:
https://www.tomshardware.com/featur...gs-benchmarks-performance-system-requirements
personally id say ur current system is still good for 1080p gaming, if u dont have any qualms about the experience then i dont see any reason to upgrade. if u really want to, u could probably get away with a cpu and gpu upgrade to follow the value gaming rig (or the midrange pc if u want more gpu performance), no need to buy a whole new system for 1080p gaming. so yes, the high end gaming pc reco is going to be overkill, though u can follow its cpu + mobo + ram config if u want a cheap path to current gen.
D4 is now that uses 21+ gig of vram on my gpu... Max framerate 175...but only about 1/2 the load (4090).
BiG_FisH
ok thanks! I will take reference to that. Good to know that I didn't have to get a complete new system.
with ur current setup... to me.. just upgrade the cpu to a 5700x or 5800x3d pair with a 6700 and u are good to go..
it would cost u 600-700.
thank you for the input, let me go research more.
xAhLonGx
Hi guys, decided to up abit of my budget and I have come out with the following after adjusting from the recommended build. I'm leaning more towards intel build for an extra $100 but still cant decide, mainly for some light gaming D4, photo editing and andriod emulator. I also realize some gpu using 12vhpwr connector, would it be of any issue if using it on the non ATX3.0 psu. Thank you.
Intel
core i5-13600kf + gigabyte b760m aorus elite ax d5681dynacore
Thermalright PA 120 Se45shopee (Bought)
GSkill Trident Z5 RGB 32GB (2x 16GB) DDR5 6400MHz CL32200Carousell
Crucial P3 Plus 2TB PCIe 4.0 3D NAND NVMe M.2115shopee (Bought)
zotac rtx 4070 twin edge863tradepac
Msi MPG A750GF-750W Gold Modular Psu145dynacore
Total:2049
AMD
ryzen 5 7600 + asus tuf gaming b650m-plus wifi574dynacore
gskill flare x5 2x 16gb 6000c32 ddr5 expo *highly recommended to tune timings192dynacore
Total:1934
deepblue_82
Daty41
21+ ram gpu? u running 4k or 8k?
1440p ultrawide all on max settings. i set the max foreground fps to 175, background to 50. The 21+ gig VRAM usage is during foreground. That y curious what other GPU is using? I dont find D4 as a particularly graphics intensive game.. (the GPU load also very low)
deepblue_82
which mobo to go with 5800x3d? and my PSU can support the 7600?
your mb supports the 5800x3d u just need to bios flash update it just in case.
your psu is pretty good should be able to support but how old is this unit?
deepblue_82
ok u win all max.. i cant afford
BiG_FisH
PC was built in 2019
I thought with the CPU & GPU upgrade, maybe I should change my mobo/RAM/PSU too.
deepblue_82
Processor - Ryzen 5 2600 + Gammaxx GTE
Mainboard - MSI B450 Tomahawk (the mb supports 5800x or 5800x3d)
Graphics Card - Zotac GeForce 1660 Ti (upgrade to 7600)
Memory - Team T-FORCE VULCAN Z 32GB DDR4 3200MHz
Storage Drive - Crucial MX500 1TB / Seagate Barracuda 2TB
Display - Xiaomi 34" 21:9 144Hz
Power Supply Unit - Seasonic FOCUS PLUS Gold 550W https://www.amd.com/en/products/graphics/amd-radeon-rx-7600
Casing - Fractal Design Meshify C TG
of coz u can spend 1000-2000+ for a brand new system but because with your mb and ram its pretty wasteful.
all comes down to how much are u willing to spend.
FatalethaL
I share the same sentiments regarding D4's graphics. It doesn't look demanding, but for some reason, it drains the resources and life out of the GPU.
I am gaming it at 4K reso, Ultra graphics settings, with DLSS 2 (Quality). On average, it puts about 50% load on CPU, and 98% load on GPU. FPS typically float at about 120.
I am running AMD 5600 (Vemeer, April 2022), 32GB DDR4 3600MHz CL16 (16GB x2) Kit, RTX 3080 Ti.
deepblue_82
well the requirements did say about the 32gb ram
the cpu requirements is not that high but the ram and gpu is higher...
Ultra 4k​
  • OS: 64-bit Windows® 10 version 1909 or newer
  • Processor: Intel® Core i7-8700K or AMD Ryzen™ 7 2700X
  • Memory: 32 GB RAM
  • Graphics: NVIDIA GeForce® RTX 3080; NVIDIA GeForce® RTX 40 Series for fully supported DLSS3 or AMD Radeon™ RX 6800 XT
  • DirectX®: Version 12
  • Storage: SSD with 90 GB available space
  • Internet: Broadband Connection
* 4k resolution, ultra graphics settings, 60fps
BiG_FisH
ok got it, have hooted the CPU.
For GPU, are there any other options around the same price/performance range as RX 7600?
NightRaven49
$733
$55
good picks overall, though if just gaming, i would opt for the ryzen 5 7600 with a cheap b650 which would provide the same level of performance for less money. the cooler is quite a recent model, so it should support lga1700/am5 natively, though i would go for the pa120 non se for just $2 more with slightly better thermal performance as the lancool 216 should fit it too.
$181
good pick but i would suggest getting the adata xpg core reactor 750w for almost $20 less, comparable quality to the focus. u actually dont need this much power either, u can drop to 650w or even 550w with the 4070.
i dont think that $100 premium is worth it, youd be getting very similar performance either way. in fact id argue going ryzen is the better choice as u have a more certain upgrade path to future cpu architectures on top of being cheaper.
u will need an 12vhpwr adaptor, but nowadays it should be included with cards that need it. again, 4070 doesnt need 750w, and most aib models still use the conventional 8p pcie power.
ur b450 tomahawk is an excellent am4 motherboard, no need to upgrade and can handle the 5800x3d very well. 7600 is also not a very power hungry card, 550w more than enough and ur unit is also good quality, so nothing to worry about.
not needed, u spend more replace also no difference.
local stock wise, no. u can refer to this table i did a while back; local pricing for previous gen is also either scarce and/or quite unreasonable, so they should not be considered. as deepblue mentioned, u can get 6600 for under 300 which would be the value champ but that is amazon pricing for export set, meaning u dont have support if u encounter issues after the return period.
creator88
Hi everyone,
I'm planning to put together a new system (with RAM, SSD and SPU purchased from Amazon) and the rest locally.
Usage: Mainly word processing, surfing, photo editing, video editing, rendering, light gaming
Software I usually use: Office, After Effects, Photoshop, Premiere Pro, 3dsMax, C4D, Stable Diffusion
I'm uncertain whether (i) 850W will be sufficient, (ii) whether the DDR5 RAM will be entirely compatiable with the board (its listed on the compatible RAM list of MSI website). Intel Z790 seems to offer more stability with DDR5 RAM.
Appreciate any thoughts/inputs on the parts below?
AMD Ryzen 9 7900X (12 core)
MSI PRO X670 P- WIFI
CORSAIR VENGEANCE RGB DDR5 RAM 96GB (2x48GB) 5600MHz CL40 Intel XMP iCUE Compatible Computer Memory - Black (CMH96GX5M2B5600C40)
XFX Speedster MERC310 AMD Radeon RX 7900XT
Seasonic Focus GX-850W Gold Modular(10yrs)
Samsung 980 PRO SSD 1TB PCIe 4.0
Arctic Freezer II 360
Corsair 5000D Airflow Type-C TG Casing (White)
Initial cost estimate is around S$3.5k
NightRaven49
more than enough for even a 4090 system. i would also have suggested buying the psu and ssd locally for the long term warranty support: psu rma will be a pita if need to ship overseas (which is likely if u bought from amazon) and local nvme pricing is pretty good these days.
if ur using the adobe suite like after effects and premiere pro, u would be better off going intel (with igpu) + nvidia, which would also alleviate ur concerns about ram compatibility (ie xmp on am5). u did mention that the kit is on the mobo qvl though, so i dont think there would be anything to worry about. for stable diffusion it is also better to go with nvidia for cuda support (compared to significantly reduced performance of radeon cards for ai workloads), though their limited vram buffers might be an issue. the 7900xt is also really poor value locally anyway.
for the parts to get, these are what i would suggest:
core i7-13700 non f + gigabyte b760m aorus elite ax d5831fuwell
arctic liquid freezer ii 360157tradepac
corsair 5000d airflow184tradepac
total: $2035
