DIY PC Rig Recommendations For 2026
deepblue_82
then for new builds 16gb ram is like min...
should be looking at 24gb......
16gb will be cutting it too close...
more with those using higher end gpus running 2-4k
NightRaven49
Anyone build any budget system for stable diffusion?
for ai tasks, generally u would want to look at nvidia. u can take the value gaming pc recommendation and swap out the 7600 for a 4060 if u are okay with 8gb of vram. if not, u likely have to look on the used market for 2080tis. if not okay with used, next step up is 4060ti 16gb already, but i wouldnt call the entire system budget at that point...
elvintay07
Suspended
What about amd 5600x + 3060 12gb vram + ssd? I presume 2080ti is lower specs that 3060 and 4060 also?
zcheez
I'm interested in going for the InvaderPC Master MK 3 current promotion, would like to get recommendations on what upgrades/changes I should ask them for?
SGD $ 1,588.00​
Specifications:
- IM7600X4070-WH20
- AMD RYZEN 5 7600X 4.7GHz 6CORE/12THREAD
- ASUS TUF GAMING B650M-PLUS WIFI AX ARGB
- COOLER MASTER HYPER 212 SPECTRUM V3 ARGB
- KINGSTON FURY BEAST RGB 5600MHz 16GB(8GBx2)
- ASUS DUAL RTX4070 12GB GDDR6X
- WD BLACK SN770 1TB GEN4 NVME M.2 SSD
- SILVERSTONE ET750 750W 80+ GOLD
- SILVERSTONE FARA 312Z
NightRaven49
not a bad choice too, though 3060 is quite slow by today's standards. u should do ur research to see how it stands relative to other cards in ur intended workload (stable diffusion has quite a few different implementations).
yep as mindgamey mentioned, 2080ti is similar to 3070 in gaming performance. so it is generally faster than both 3060 and 4060.
Strange 2080ti seem like more ex than 3080ti
where do u see that and how much? if so then between the two u should get the 3080ti, though a 4070 may make more sense.
SGD $ 1,588.00​
Specifications:
- IM7600X4070-WH20
that is insanely cheap. I would top up for a better psu like the rog strix 750w and if ur budget allows, a cooler upgrade to something like the pa120 (though u might need to contact them) and the ram upgrade to 2x 16gb 6000c36.
elvintay07
Suspended
SGD $ 1,588.00​
Specifications:
- IM7600X4070-WH20
Actually this price quite steady. If you customised a set at sim Lim, I think you spend same price but get lousier spec
elvintay07
Suspended
Actually can don’t upgrade also. $1588 already a beast
oceanstar
Hi All, may i know if this have typo? unable to find this exact model
i can only find CL30 and CL40..not sure whats the difference. TIA
adata xpg lancer 2x 16gb 6000c30 ddr5
NightRaven49
c30 is shorthand for cl30. cl refers to cas latency, which refers to the number of clock cycles the ram needs to access and return data after a read command is given to it. the faster ur ram can access data stored on it the better, so ideally u would aim for a kit with a lower cl value (in turn meaning lower latency) at the same frequency (mhz).
arvinsim
go for 32GB RAM. I think the upgrade was less then $50
Also, if you are okay with last gen CPU (5600), for around 1700 you can get the 4070 TI
NightRaven49
i wouldnt recommend it, the 5600 will almost certainly bottleneck the 4070ti at any resolution lower than 4k (and might still be an issue at 4k).
zenitro
Hi is there any recommendation for a gaming PC. 1440p.
Planning to get the whole system build by someone (eg, Invader or Aftershock or private builder.) li so as to minimize headache when got issue and need to diagnose parts by parts.
Several thing I am unclear on
- go for RTX 4070? or is RTX3070 more value for money? or is 4060/3060 good enug?
- DDR4/DDR5? 16G or 32G
Budget ~1.3k - 1.4k
mindgamey
Budget ~1.3k - 1.4k
Throw in 7800 xt
velcry
Budget ~1.3k - 1.4k
Work backwards from the target end-state you want.
When you say 1440p gaming, are you looking for high-end AAA games (e.g., Starfield / Hogwarts / Control) or low-to-mid-end games? Ultra / high settings? 60 fps or 30 fps?
Generally, if you are fine with dialing back some settings so that you game on "high" instead of "ultra", and you're fine with 30 fps, then no need for 4070. 3070 or even 4060 / 3060 good enough.
zenitro
I would say a mixed of new and old games. High setting would be enug but 60FPS on average would be good.
On very high demanding titles, I dont mind going medium setting but still wish to average 60 FPS.
Would 4060 still achieve that?
mindgamey
4060 overpriced tbh.
deepblue_82
old games maybe so... but new and demanding titles.. with mid u might not get 60fps plus at 8gb not really any dlss or rt we should look at.. calling @NightRaven49
