dreameredz
- Jan 4, 2010
Hello,
I don't do much posts but I have a question. Basically I bought some Corsair Vengeance Pro 2400MHz RAMs, CL11 at 11-13-13-31, 4x8GB, cos they were cheaper.
But I've just found out that it's actually running at 1.65v.
I'd prefer to run it at 1.5v to hopefully have it to be cooler and can use longer or something...... so I was considering to downclock it when all my parts arrive and I put the comp together.
Was wondering if anyone could advise me on the clocks? Like if I put it to 1333/1600MHz, do you think I could run the thing at like 9-9-9-24? (or is it 9-9-9-27, how do I even calculate this?)
And also, will there be any sort of risks to downclock a factory overclocked RAM?
Do I down the voltage first or the clocks first or both together?
What I'm afraid of is that I'll lose performance after I downclock it or lessen the life of the RAM or something.....
Or should I just leave it at default and just use XMP and don't care about the heat..?
