Dry Cabinet
JAson1980
Seriously I didn't use dry box when I first started up, and a few of my lenses can't be used cud to the coating (lens element) being eaten by fungus!!
For serious photographers, one should consider getting a proper dry box. If on a low budget, just get an air tight Tupperware and buy silica gel and put inside. Get a hygrometer from Daiso or 100yen shop if you ever go to Japan. When the gel changes color, just buy new ones or sun them under hot sun.
And if your budget allows, get the digital ones, like EJB suggested the DHC series. Anyway AD series will do.
For price, DHC series are their most expensive range. I have a DHC60 and DHC120. The 120 costs SGD458 (bought 2 weeks back). My suggestion is that always buy twice the size you need. It is my shortsightedness to get the DHC60 a few years back, thinking that is is just enough. Since then I have been stacking stuffs until i got to be careful opening the door. I couldn't take it anymore so I got the DHC120. The boxes have a long 5 year warranty so you will have peace of mind for at least 5 years.
Someone asked why no one suggested Aipo. Go to clubsnap for answers and user experience.
Anyway, you can also put in other stuffs like your leather wear inside to prevent fungus growth
Bro, you remember how much u got the DHC 60 for?
I am looking to upgrade from a AD30 to the DHC60
James Tang
Can't remember, I think SGD250++. You can email digihub (the supplier for DIGI CABI) for quote. The quote should include GST and delivery.
They control their pricing as I got another quote from another shop, their authorized dealer, also the same price as delivery is still under digihub
JAson1980
Oic thanks. from the link given by skimmilk, parisilk selling for $240.
Think i will try there first
RockaRolla
I went to parisilk in the afternoon to order the DHC60, i paid $258
maybe you could try getting e-quote or call them first, not sure if can get slightly cheaper price, since from the link the person got it for $240
Frontiers
got myself a DHC60 as well at 238 as shown on my receipt with delivery but that was some promo 1+ years ago :(
with delivery~
SkimMilk
haha... the blog belongs to me. =p
I got it for $240. Just did a walk-in. Shop owner gave me a discount without asking so I bought it immediately. But that was last year, ard Apr?
SkimMilk
call and ask bah? the moonlight series adds the lighting in cabinet. When I was getting my cabinet, I was told they are not bringing in anymore. But that was almost a year ago.
voiceoflove
just called them, no stock liao
mvp30sg
Advice on dry cabinet placed in humid storeroom
Hi all,
Just wondering is it advisable to place the dry cabinet in a typical HDB flate store room/ bomb shelter where it's humid and minimum air flow?
Will it consume more electricity/ power?
Thanks.
James Tang
Suggest putting in a more airy location. Bomb shelters are kind of closed space. Reason being the drying unit emits heat and you dont want heat to get trapped in a small space
