Dual HDMI problem
MevolutionX
Hi, I have a PS3 & a PC both using HDMI to connect to my display. However, my display only has 1 HDMI port. Every time I want use my PC I had to unplug my PS3 HDMI (vice versa). Is there such thing as HDMI splitter? Where are I get them?
hellhole
dun have... such thing.
only have a hdmi box... ala a switch box for those printer...
can find at sls... 6th floor
Kiwi8
Deluxe Member
What display ports does your monitor have? If it has DVI, then use DVI to connect your PC to the monitor lor.
MevolutionX
No DVI, got VGA but VGA doesn't carry sound signal. The HDMI splitter i posted won't work? :(
Kiwi8
Deluxe Member
Ok then u will have to look for something called "HDMI selector". That takes in two or more inputs and has one output. It also has a selector to decide which input to send to the output.
t258jgn
You need this
hdmi-switch-01.jpg~original
xonix
Do the AMD HD5000 series support sound via DP ?
Maybe TS can go DP for 1 monitor and HDMI for the other.
shadow84
His 5850 have DP, HDMI, DVI.. But problem is that his TV only have HDMI.... and to TS, your TV only got 1 HDMi port?
xonix
I goggled a bit on this issue. It might be possible for TS set up connection like this.
PC > DP to HDMI adapter (with audio) > TV HDMI #1
PS3 > HDMI > TV HDMI #2
But unfortunately TS mentioned in the OP that he only has 1 HDMI port for the display.
So HDMI switcher is the only alternative:
http://list.qoo10.sg/item/3-PORT-HDMI-SWITCH-SWITCHER-SPLITTER/404439063
MevolutionX
