Is your Livolo 2 way working?
Nop.. I gave up trying..
i still cannot get push notification to work for my Broadlink door and motion sensors.
Recently bought a Xiaomi security cam, also cannot send push notification to my phone.
remote access is fine though. both wifi and data 4G.
not sure what is wrong.
any experts on this? do i need to enable a port or something from my router?
its so stupid that i need to check on and off without push notifications...
I thought fan remote is RF? KDK IR remote ar?
How to check if it is rf or ir my is Panasonic ceiling fan. I had trouble getting it work with broadlink.
i had the S1
Not sure is it s1 issue, think u r the second person i know using s1 and notification cannot work.
i recently got a xiaomi IP cam.
the push notification also does not work
not sure if its my home network
Actually should use ihc or e control?
I have a Broadlink TC2 1-gang that switches itself off usually in the evening. Not sure if its because of someone nearby having the same set-up or a installation issue. It never switches itself on so I'm leaning more on the installation part.
Thinking of changing to another brand. Which is better recommended for a HDB flat?
anybody using pro or mini 3 with Starhub set-top boxes? can work?
Seems like quite a number of u guys having issues with broadlink tc2 switches. Im using livolo switches so far no issue. If u guys wanna change, can consider livolo rf switches.
Can oso buy a seperate main livolo rmt04 physical remote to control all the switches, and oso use to learn as tv template so that alexa can control if u interested.
Any recommendation where to get the Livolo switch? Also is a remote needed to get it to pair with RM?
Yeah, got most of the home automation down, just this single light switch that's slightly irritating.
