nangka1
- Nov 26, 2005
"ART promises a performance boost in applications, better battery life, and lower memory utilization, so while waiting for root figure I'll try this out.........
The first thing you're going to need to do is enable the Developer Options. Go to Settings> About Phone, and scroll down to Build Number. Tap on the Build number 7 times until a notification pops up and says that you've unlocked developer options.
Press back to the previous settings menu, where you should now see the Developer Options menu. Jump in there and tap on Select Runtime. Select ART, and you'll receive a warning asking if you would like to switch from libdvm.so to libart.so."
Would this improve performance?
