Entry level conti car comparison
edwinttt1978
Does Lexus share the service centre with others of the Toyota family?
Or is there an exclusive service centre for Lexus?
edwinttt1978
It’s an intended feature. If you are used to driving Japanese cars you will think the bmw steering is heavy. It’s meant to be precise driving at high speeds. The newer Bmws has electric steering that adjusts stiffness according to speed but many diehard fans complains about it.
The old BMW steering is so much better. The newer steering, Servotronics, does not provide the same feel at all. BMW has also lost its “angel eyes”, another hallmark of BMW from afar.
Fortunately, some car companies allow selection of steerings: comfort or dynamic.
HMAN
Indeed, 116d is a fun drive for it retains its rear-wheel drive, the hallmark of a fun drive.
Yes I am driving 116d now, for its class or category, yes pretty refined and good drive.. Last gen of RWD 1 series.
Sent from Google PIXEL C using GAGT
edwinttt1978
Then drive Jap or Korean cars all go fly kite liao
Jap or Korean brands do not make such slogans mah, although Honda’s “The Power of Dreams” will always be a dream for me.
BMW’s is eye-catchy and truthful: The Ultimate Driving Machine.
HMAN
Any creaking sounds emanating from the doors?
There is creaking sounds but you just need to do simple mopping between door rubber seal and the floor base to clean up water residuals, once done no more sounds
edwinttt1978
So easy? Okay, will try one day.
