Entry level desktop + printer
ZenTape
Hi, please advise an entry level desktop for a small tuition centre & stationary shop.
Main uses:
- keying in customer parriculars
- inventory updates
- accounting entries
- light Web surfing and movie watching.
Main worries is the backup of the customer details.. So would prefer a solid hdd to avoid easy corruption.
Please also recommend a laser printer that can fax print copy scan.
Inclusive of a monitor, budget is around $1.2k. If below $1k even better as it's really a small home biz.
Thank you so much..
MoneyFace =p
Main uses:
- inventory updates
Thank you so much..
Are you capable of repairing PC? If you need on-site reparation support, you should still go for branded ones for a peace of mind.
MoneyFace =p
Something like this will already be sufficient:
CPU+MB: Intel Pentium G2130 + ASRock B75M-DGS @ $145
RAM: Crucial DDR3-1600 CL11 4GB @ $45
SSD: Plextor M5S 128GB @ $127
HDD: Western Digital Blue 1TB @ $76
Moderately-performing, yet solidly-doing HDD with raving reviews.
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
CASE+PSU: In Win BK644 + Powerman IP-P300BN7-2 300W SFX [80 Plus] @ $89
Small chassis that is more ideal to lay horizontally on table.
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
DSP: Dell S2240L 21.5" LED [e-IPS] @ $199
Great IPS panel for rich colours and viewing angle. Clear finish screen though.
3 years warranty.
Total: $817
Optional:
DSP: Dell UltraSharp U2312HM 23" LED [e-IPS] @ $248
Matte non-glaring finish ensuring best viewing experience in brightly-lit environment.
5 years warranty.
Buy from GS (Nigel) or Fortran (Ivan). Prices reference from SLS stores.
Great people to patronise especially when you need troubleshoot assistance.
I don't have much experience with using laser printers but have been using HP ones in office (from SAF lah) and so far so good. :)
junialum
A solid state drive (SSD) is less susceptible to failure than a normal hard disk drive (HDD) but it doesn't mean that your data would be safe just by using a SSD instead of a HDD.
An easy way to make sure your data is safe is to always back things up. It could be making a daily copy to a thumbdrive or even using free cloud sync software like Dropbox (so that your files are always backed up online - needs an internet connection).
MoneyFace =p
Had been thinking to recommend SSD but the irrecoverably of any accidentally-destroyed data (especially after TRIM) made me rethink about this.. Perhaps i am too paranoid about this... :o
localITguy
Suspended
Parts:
Monitor : AOC 20" E2060swd (19.5 inch) ( i use this myself. its decent and good for normal use. i guess you don't need a big monitor unless you play games right..)
Sharkoon MS120 (BUNDLE)
PSU Bundle Selection: Seasonic SS-500ES 80+ Bronze
WD 1TB SATA 6GB/s, 16MB Cache, 7200RPM (Caviar Blue)
G.Skill Value 1600MHz 8GB(1x8GB) 11-11-11-28 (F3-1600C11S-8GNT)
Asrock H81M-DGS (BUNDLE)
CPU Bundle LGA 1150: Intel® Core™ i3-4130 BUNDLE
Total $696
Buy @mynextcomonline
i dunno about printers sorry :D
I think for you an HDD is a better option over an SSD
