Exchange Rate - Part 2
calkel20
ok bro, i just walked abit far to find a Bank of Taiwan ATM to withdraw money and indeed it is THIS BANK's atm that gives super gd rate with NO FEE for Trust card.
i just withdraw twd3k and the rate is 22.805!!
Huat ah!
Rates good good.
Joelleyuan
That could be the reason why.
no lor,
i mentioned i used that green logo atm in a mall. not airport.
after that i used another one in Ximen Mtr Stn and another in xmd streets, all suck. say wanna charge twd100.
evilduxy
oic thanks so is use bank of tw it seems!
thanks!
calkel20
no lor,
That means can only use the purple BOT liao.
Green Cathay not good for your use.
Joelleyuan
i used Cathay Bank ATM to withdraw twice and they don't show me the rates.... Just straightaway dispensed the cash.... and i will check the rate against the card's app....
so have you check? what's the rate for Cathay Bank?
Seifer28
Just FYI~
the fx rate doesn't come frm cathay bank
it comes frm ur card provider.... could be youtrip could be trust
so if you are seeing the exchange rate at the ATM, you shld be choosing something wrong that resulted in cathay bank doing the forex exchange
Joelleyuan
Just FYI~
oh really? i just select withdrawal and key in amt then it showed me rate.
another one 永豐銀行 say will charge twd100,
while BoT one is straightforward, select withdrawal select savings account and it dispense cash.
So what rate did you get with your card from using Cathay Bank atm?
Seifer28
https://forums.hardwarezone.com.sg/threads/exchange-rate-part-2.5721636/post-144844616https://forums.hardwarezone.com.sg/threads/exchange-rate-part-2.5721636/post-144995794Please check my previous posts #1,267 #1,284.... i was there Mid Nov - Mid Dec
calkel20
兆豐銀行吧 or 匯豐銀行?
Joelleyuan
Bro, pink colour leh.
outside airport maybe don't have this pink colour lightbox but BoT atm also not purple, is maroon.
The currency exchange one then is Purpleish.
Anyway, currency exchange one will write damn big "currency exchange", hard to mistake lah.
calkel20
Okay la.
My color code not as strong as yours.
So you wanna write a guide on the best rate?
evilduxy
so this is the 1 which u got the best rate righ?
Joelleyuan
yes, and there are ALOT of this bank's atm at the airport.
once u leave airport, become hard to find. those convenient stores and mtr stn one all Cathay Bank or other bank, either lousy rate or wanna charge twd100.
evilduxy
oic if thats the case maybe reach airport just draw 1k first
tks
Joelleyuan
tks
yup, otherwise u gotta search for their location on google map and see where is convenient for you.
There's a Bank of Taiwan branch near ximending. It's about 5-6 min walk from exit 2,
but if you're on the outer side of ximen station, then it could be a 10-15min walk.
i discovered a very good noodle shop while searching for this. I will and must visit the noodle shop again next trip!
