Snoweagle
- Sep 6, 2005
Hi guys, this month after my data reset on the 8th, up to now my data usage is only around just over 1GB and with reference to the MySingtel app, still shows 1.0GB. Usually after that, I use *3282 for a more accurate data monitoring in 'MB' so can adjust accordingly with the Data Usage app i'm using which is a very good data monitoring app.
But ironically from last nite since, *3282 has been clocking 500MB of usage to now but i've only used around 40MB and yes, MySingtel still shows 1.0GB and *3282 is now showing in 'GB' and in units of 100MB, so irate, i called 1688 twice and one tells me it is 1.5GB of usage and the app i'm using might be inaccurate or maybe background apps are running and the other tells me app like whatsapp even closed will consume data in which I think they're trying to cover up or they really cannot answer. The thing is, background apps refresh is always disabled and my cellular usage which I always reset on the first day of the month shows that my whatsapp only used 8MB to now, so it's impossible. Previously all are ok.
Anyway just awareness for all Singtel users to check their current data usage to date as I really don't know where the other 460MB of extra data comes from. If Singtel were to charge me for the extra data usage for my next bill, will just have to lodge a complaint.
