Mythmaker
- Nov 29, 2004
Fan controllers answers are so hard to find, googled a few hours still no result lol... hopefully someone can help clear my doubts
1) Does a FC have the same concept as a speaker? As in variable resistor controlling voltage to fan determines how fast it will spin?
2) If the fan emits high pitch sound when set at every other setting other than the max setting, is it the fan's fault or FC?
3) Following #2, what if the fan is tested okay at 5v and 7v via connecting from PSU? That means no high pitch noise. So is the fan controller faulty?
4) If it's the fan controller that is faulty, is it possible to solve the issue by changing the capacitor (gather from google that mostly is capacitor problem)? If so which capacitor should be bought?
5) If a FC says it supports 50w per channel and you have a fan running at 12v*0.25A = 3W, does that mean that it's possible to attach 16 of such fans to a knot?
thanks alot guys...
thanks alot guys...
