Fans Reviews
deepblue_82
can anyone reccomend me a good value casing fan.. i wan to change mine..
i think its should be a 120 one.. i just want something long lasting.. not too ex..
adrianlee
Thermaltake Launches ISGC 12 cm Ultra-Quiet Fan
Thermaltae is out on the market with a brand new multi-purpose 12 cm fan. The ISGC fan appears to come with some odd curves on the blades at first sight, but this is for a reason - to help keep the noise levels coming from spinning to the absolute minimum. The 120x120x25 mm ISGC uses Hydro Dynamic Bearing (H.D.B) system, spins from 800 to 1300 RPM and has max aiflow of 58.3 CFM at only 16dBA. In the package you'll also find four rubber vibration-absorbing mounts. The ISGC 12 cm fan is yet to be priced. For more information, click here.
Source: Techpowerup
MadLocke
HDB.. hydro dynamic bearing.. :s11:
isn't it juz another term for FDB.. fluid dynamic bearing?? :s22:
s-flex already using FDB.. :D
hlw8888
is there a relatively cheap yet silent & has good airflow 80mm fan ah? :o
cos i see most ppl here recommend 120mm fans.
Sergio Ramos
is there any good 120mm fans for "Exhaust" and "Side Panel"? cause my comp have no front fan so need a very good fan to exhaust those heat from comp, dun care about noise.
zero7090
adrianlee
30x 120mm Fans Roundup
Today we have a guest article from Martin who tested 30 different 120mm fans when mounted on a water-cooling radiator. He measured generated noise, cubic feet per minute of air moved with each fan, allowing for some impressive comparative result charts. If you arere looking for a 120mm fan upgrade, this article is a must read!
http://www.madshrimps.be/?action=getarticle&articID=936
adrianlee
What's the best 120mm case fan?
We've collected 22 120mm fans and put them through rigorous noise and airflow tests to see which is the best. Read on to see how to keep your hardware cool while keeping the noise your PC makes to a minimum.
http://www.bit-tech.net/
adrianlee
What's the best 80mm and 92mm fan?
The hardware you use to cool your CPU is arguably just as important as the CPU itself - if it's loud then you're not going to want to use your PC all that often, while a limited amount of cooling will result in your CPU running hotter than is ideal or having limited overclockability. An easy upgrade to your cooler is to change the fan, so bit-tech is here with a roundup of 80mm and 92mm fans that are ideal for smaller coolers.
Of course, these fans are equally at ease being fitted in a case mount. Whether you've just got an old case that doesn't have 120mm mounts, or it just happens to have a few 80mm or 92mm mounts in odd places (the side panel, behind the CPU socket, or mounted to the hard disk caddy, for example) read on to see which fan will suit you best.
http://www.bit-tech.net/hardware/cooling/2009/10/15/whats-the-best-80mm-and-92mm-fan/1
