FAQ: Purchasing a DSLR System
EJB
WoW good job bro!
Such a enlightening read :)
At least I don't feel so dumb lol
Aiyoh... please don't say that, I also started with 0% knowledge, and till now I'm still learning, just helping others who wants to know what DSLR is really all about :)
EJB
Think you're looking at Dry Cabinets as opposed to dry box, they are of different calibre, thus different pricings.
lammie89
any recommendation for a basic DSLR? since there is quite a number of new models out now.. >.<
and isit advisable to get an additional lens for portrait or wide lens?? >.< :look:
bunegg
550d :) with either kit 1 or kit 2
spend another $125 on a 50mm 1.8 for some bokeh goodness :)
dlabedz
1st DSLR
The 550D is a great first DSLR.
Save a little and get a better lense like the Canon EF-S 15-85mm f/3.5-5.6 IS USM.
There is a review at Cameralabs, I do not have enough post here to allow me to post the link. Put Cameralabs in a search engine and you will get the link.
Good luck and happy shooting!
funnyhercules
Hey EJB,
Thanks for your post, has broaden my knowledge about DSLR.
By the way i'm looking for a entry level DSLR, would you recommend D90 or D7000?
EJB
Entry level will depend on your budget, a decent entry level, 3100 or 7000 would be just fine.
bluebellas
Lens cracked
Hi, can anyone advise if it's ok to continue to use a cracked lens. Someone told me moisture will seep thru the crack and spoil the cam. I noticed thou that I can still take pics without the crack showing. Very sim Tia cos I bought my cam and lens just recently.
chanzhf
i feel for you. depends really on the extent of the crack. if the value of the lens isnt that expensive and if the crack doesnt excessively affect your pictures, i'll say go ahead and use it.
replacing any of the glass on a camera lens involves alot of effort for disassembly. add in the cost of parts replacement, some of which are really difficult to obtain, and u might as well just buy a whole new lens.
As for moisture issues, never heard of cracks in lenses leading to camera body damage. the most common damage which are fungal growth and dust spots are due to improper storage conditions such as humid conditions.
mvp30sg
Hi EJB,
I was reading thru your post on the explanation of "Zoom Times" and I'm more confused now.
All along I've a rough concept on those bundle lens for eg. 18-55mm, Zoom times = 55 / 18 = 3x
18-135mm, Zoom times = 135 / 18 = 7.5x
18-200mm, Zoom times = 200 / 18 = 11.1x
But how abt those Lens with 55-300mm, 70-200mm, or 500mm?
Is 18mm the reference for actual size?
Please forgive my ignorance as I a newbie and I'm trying to pick up some serious photography.
Thankyou. :)
EJB
Hi EJB,
Thankyou. :)
55-300 = 300/55 = 5.45
70-200 = 200/70 = 2.86
500 = 500/500 = 1
The division is done taking the SHORTEST end and the LONGEST end's range. 18mm on the examples given are also calculated as such.
bluebellas
Cracked Camera lens
Thanks a lot for your advice :)
