Fast charge
maybe buy this charger will have the best of both worlds (connection)
why PD charge must use usb C connector, if need to sync with pc, still requires a usb C to normal usb connector;):(
Because that is part of the USB PD specifications.
Ref:
https://www.zdnet.com/article/usb-p...est-way-to-charge-iphone-and-android-devices/
Now I use two original Huawei 22.5W quick charger for my Huawei P20 and Nova 5T (edited: both support Huawei SuperCharge up to 22.5W).
And then we have three Apple 10W chargers for iPhone X, 7+, iPad 2018 and iPad 2019. Among them only iPhone X supports USB PD fast charging but so far I do not see the need yet.
For the older Oppo R11S, the Oppo fast charger is not bad.
And I have the Ugree two port USB Type A 36W charger as well for other devices (not really utilizing the fast charging QC 3.0 capability).
https://www.ugreen.com/collections/wall-charger
Maybe I will take a look at the Ugreen USB PD charger later this year after getting iPhone 12.
Hmm, it seems to me iPad 2019 (7th generation) does support USB PD quick charging.
https://www.apple.com/sg/shop/product/MU7W2ZP/A/18w-usb-c-power-adapter
The compatible list shows iPad 7th generation is supported.
Probably I will buy a USB PD charger sooner than I have planned. :D
saif07
Yes, my Acer Swift 3 laptop bought in Dec 2017 already has the Type C port, but I think it is not for charging purpose.
it can charge albeit very slowly due to USB 3.0 standard which is 0.5A. The newer swift 3 has a TBT3 USB C port that can sync and fast charge to PD standard
szeli
USB 3.0 shud start charging at about 1A
Mclairs83
i only uses ugreen power adapter and cables.
used Baseus cables before. spoilt within 6mths.
https://en.wikipedia.org/wiki/USB_3.0?wprov=sfla1
Supposedly a normal USB 3 port can provide 5V/900mA to a high power device.
Normal USB 3 Type C port is supposed to be able to deliver 5V/3A.
Then USB PD 3.0 enabled Type C port can deliver up to 20V/5A.
But I do not have any equipment to measure the real world charging current.
