First build
Cha0yue
This is my first time on hardwarezone so apologies if I'm not supposed to post here.
I'm making my first PC build and this is what I'm going for:
Part nameItem nameSellerSell linkPrice
CPUR5 7600XCraftfixbuild308.00
CPU coolerThermalright Peerless Assassin 120 SE ARGB coolerdynacore65
MotherboardX670-P WIFIAmazonhttps://www.amazon.sg/MSI-X670-P-ProSeries-Motherboard-Wi-Fi/dp/B0B6Q1N477289.63
RAMCORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB)Amazonhttps://www.amazon.sg/CORSAIR-VENGEANCE-6000MHz-Compatible-Computer/dp/B0B15DST2L139.29
SSDWd Black SN770 5150MB/s Gen4 Nvme M.2 Ssd(5yrs)Dynacore69
GPUsapphire pulse amd radeon rx 6700xt 12gb gddr6Newegghttps://www.newegg.com/global/sg-en/sapphire-radeon-rx-6700-xt-11306-02-20g/p/N82E16814202400507.59
PSUCorsair RM Series RM850XAmazonhttps://www.amazon.sg/CORSAIR-RM850x-Modular-Supply-CP-9020200-NA/dp/B08R5JPTMZ195.49
CaseFractal Design POP Air Rgb Black TG Tint CasingDynacore135.00
TotalSGD 1709.00
I'm also thinking of buying this monitor https://aoc.com/us/gaming/products/monitors/24g2sp
from shopee for $269
And does anyone have a recommendation for a mechanical keyboard that is less than $100?
Solution
I can't find the non SE and argb version but I found the non argb version for $55.
oh i meant that regular version that is not se and does not have argb. u can just get a non rgb version and slap on ur own rgb fan on it.
I can't seem to find this too... Maybe take a screenshot?
https://dynacoretech.com/parts-and-...00-micro-atx-gaming-motherboard-4711081912125
I think I may get the Asus Rog Strix 850W 80+ Gold for $185 from dynacore but I'm not sure if...
NightRaven49
decent picks overall, but there are places where u can save that won't affect the overall experience.
u could save a few dollars by going for the non x, it will perform basically the same as the 7600x.
id opt for the non se and argb version that is cheaper @ $57 from tradepac, since the pop air can accommodate the taller non se. this should also give u slightly better cpu temperatures.
MotherboardX670-P WIFIAmazon289.63
any specific reason for going x670? b650 is generally good enough, and u can get a very decent local set asus tuf gaming with warranty for $240 (dynacore) that also has a gen5x4 nvme slot.
zen4 is very sensitive to memory timings, so id tighten this kit's secondary timings as much as possible. 6000c36 is fairly loose.
PSUCorsair RM Series RM850XAmazon195.49
I strongly suggest getting psus locally as they generally have long warranties and rmaing an export set will more than offset any savings u get now. for this price, u can get the asus rog strix 850w or non x rm850 (dynacore) which are also top tier psus. however, this power capcity is very overkill for a 7600 + 6700xt build, a 650w unit will suffice for a much cheaper price (~$150).
good pick.
but u can also refer to this thread for alternatives:
https://forums.hardwarezone.com.sg/threads/summary-gaming-monitor-recommendations.6342454/
Cha0yue
I think I may get the Asus Rog Strix 850W 80+ Gold for $185 from dynacore but I'm not sure if there's warranty.
Thanks for the suggestions!
NightRaven49
if its from dynacore, it will have warranty for sure. getting from amazon though, unless u buy from sls shops, is usually as good as no warranty.
actually now looking at the total price of the build, u can actually get a 4070 build from invaderpc, which will be quite a bit faster. u can follow my suggestions here:
https://forums.hardwarezone.com.sg/threads/looking-for-pc-build-rtx-4070.6934387/
Solution
Cha0yue
I think I'll just get the Thermalright peerless assassin 120 SE (no argb).
Yeah that looks like a good deal. I'll be checking with them the price of changing the cooler and psu. Thanks for the suggestion, wouldn't have seen it otherwise.
naked123
crucial p5 plus 1tb $88 from bizgram pricelist. this pricing idk real or not as all other shops selling $10X
corsair rm850e $190 from pct pricelist. same tier as rm850x
Cha0yue
Just curious to know, which model recommended, did you decided to go with?
Sorry for the late reply. I went with this:
MASTER MK3 | R5 7600 + RTX4070
SGD $ 1,660.00​
Specifications:
- IM76004070-WH20
- AMD RYZEN 5 7600 3.8GHz 6CORE/12THREAD
- ASUS TUF GAMING B650M-PLUS WIFI AX ARGB
- COOLER MASTER HYPER 212 SPECTRUM V3 ARGB
- KINGSTON FURY BEAST RGB 5600MHz 16GB(8GBx2) CL36 AMD EXPO
- ASUS DUAL RTX4070 12GB GDDR6X
- WD BLACK SN770 1TB GEN4
- SILVERSTONE ET750 750W 80+ GOLD
- COOLER MASTER CMP 320 CASING (3 ARGB FANS)
I upgraded the PSU to ASUS rog strix 750w gold for $70
deepblue_82
SGD $ 1,660.00​
Specifications:
- IM76004070-WH20
looks good...............
