Four Galaxy Note 4 Accessories
Akai Ryu
zXioNGz
actually no need screen protector right?
not like keys or knives can scratch the screen.
just need a cover to protect the sides and back.
Almost a month my Note 4 still fully naked. Temper glass sucks, I removed it after 1 day.
But I'm getting a case not because of protection but I'm starting to get annoyed by the sharp edges of note 4.
jianrong
I also thinking of removing glass sp and put normal clear sp.
blurtaurus
Ringke Fusion case
Hi guys,
Received my Ringke Fusion case yesterday. Quite disappointed in the quality. Reasons are:
1) Edge surrounding the soft case and buttons are a bit sharp/jagged, not smooth. Although it will not cut your fingers, but does not feel comfortable.
2) Position of dust protector flap for the USB port is out. The thin piece joining the flap to the casing is too long. As such, when I push the flap into the port, one end of the flap cannot fit nicely and is pushed out slightly by the too long connecting piece. It is possible that mine is a defective one and the rest will fit nicely. Dust protector flap for earpiece fits perfectly.
I like the look of the casing but not the quality.
Just my short review. Cheers!
Akai Ryu
Hi guys,
Need some pic to verify
Lil_d3viLz
Hi guys,
Sad to hear that.
New stuff that doesnt fit ur taste, means more issues than issues solved
chewwai
I have also received mine. Agree with quality issues - sharp edges but i do not have the flap problem
Edges are sharp on all 4 sides. For mine, the bottom of the case is not flushed with the phone.
zXioNGz
isn't note 4 using the same glass as note 3. quite a few sites stated so.
if not then what glass is note 4?
It's not. Iirc it's something called Dragontrail glass or something, hope someone can sic link as prove.
But Dragontrial glass is from Japan, I never doubt Japan technology haha. Anyway Gorilla Glass 3 and Dragontrail are both very strong glasses. If you're not going to any beaches, you don't need a cheapo screen protector to spoil your screen viewing experience.
Dropping is another matter, nothing can withstand a drop so this doesn't matter if you're putting sp or not.
I for myself are not going to put sp on my Note 4. But getting Neo Hybrid as the Note 4 edges are way too sharp. Neo hybrid tpu is the solution for me.
